Thread: Main drain question
    OzPool's Avatar
    Jan 2013
    Sydney
    31
    Main drain question
    Is there a difference between Australian and US plumbing codes regarding the connection of the main drain to pump suction line? The only thing connected to my suction line is the skimmer
    45,000 L (10,000 gal) pebblecrete pool, Hurlcon Viron P320 variable speed pump, Hurlcon VX9T SWG, Waterco 21" sand filter, Polaris 3900 Sport with booster pump and tailsweep pro retrofit. Pool has a rock waterfall that is in desperate need of a re-build (currently more like a soil-water-slurry-fall). Sunbather solar heating that is also not operational (perished solar blankets).
    22,553
    Re: Main drain question for Aussies
    There's not a difference as far as I know. The only thing connected to my suction side is the skimmer. It only has one valve, and that's optional.
    OzPool's Avatar
    Jan 2013
    Sydney
    31
    Thanks Bama. I realised after a bit more investigation that my main drain IS connected to my skimmer. I often wondered what that dirt clogged hole in the front of the skimmer was for.
    When we bought the house, the skimmer did not have a weir door on it. After reading on TFP what purpose they serve, I recently installed one. I suppose the low velocity in the skimmer without the weir door led to the main drain pipe blockage.
    With a bit of effort with the garden hose and some operations of the weir door I've managed to clear the pipe. There is no valve on this pipe (at least not at the skimmer end), but there now seems to be a reasonable balance of flow between the skimmer and the drain. The drain pipe looks like a smaller diameter (1" or 1.25") than the suction line (1.5"), which I assume is to provide the flow balance.
    I assume with the drain pipe blocked, the pool was not turning over as it should be, with dead spots at the bottom?
    With the pipe blocked for god knows how long, I imagine there is a pretty disgusting bio-film/algae layer on the pipe walls - do I need to clean this (how?) or will it clear itself up during a shock treatment?
    22,553
    I would suggest you either raise the FC to shock level for a couple of days, or take a length of pipe and pour some bleach directly into the main drain. If you do the pipe thing, set your pump on low and shut it off before all the bleach is pulled from the line.
    38,547
    FYI, There are float diverter valves that sit inside the skimmer that allow you to adjust how much flow comes from the floor vs the skimmer.
    Posted from my Droid with Tapatalk ... sorry if my response is short
