Thread: CYA in the lithium granulated pool shock?
    Jul 2007
    Does anyone know if Bioguard Burnout 35 contains CYA? I am having cloud battle and ran out of bleach, but still have a couple cases of the Burnout left from before I learned BBB. My CYA is too high and I don't want to put any more in.
    14'x28' in ground with vinyl liner and a new sand filter (2015).
    Burn Out 35 is lithium hypochlorite which is fine to use. The main problem with lithium hypochlorite is that it tends to be very expensive, but if you have some already it is fine to use it.
