Results 1 to 9 of 9
Thread: Dual SWCG setup
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Dual SWCG setup
    Has anyone ever seen a dual SWCG system running parallel? I was thinking about doing this to cut down on the amount of runtime and for redundancy.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Re: Dual SWCG setup
    We commonly use triclor feeders in conjunction with SWCG's. It makes start ups easier, helps balance out the ph and CYA, works in low temps and can be a backup if one of the systems fail. They compliment each other very well.
    Christian's Avatar
    Jul 2012
    Sacramento, California
    304
    Re: Dual SWCG setup
    I have seen dual SWCG used in commercial settings but not in a residential setting. No reason it shouldn't work that I'm aware of though.
    22,549
    Re: Dual SWCG setup
    There are a couple of threads here where people are running Intex swg's parallel. It's kinda expensive but it actually makes sense for redundancy.
    Jul 2007
    Brisbane, Australia
    874
    Re: Dual SWCG setup
    you could do it, but in my opinion it's an overkill for residential installation
    Oct 2012
    604
    Re: Dual SWCG setup
    I like the idea of redundancy. I was hoping that it would extend the life of the cells by having less runtime which would also be beneficial. Does anyone know if this would require less cleaning? Does a SWCG cell accumulate calcium buildup only when it is generating chlorine? Less runtime would mean fewer cleanings.
    Jun 2011
    Long Beach, CA
    2,787
    Re: Dual SWCG setup
    The buildup that SWGs get is due mostly to the chemistry of the water. If your pH runs high then most likely your SWG will most likely buildup the deposits quicker. I keep my CSI slightly negative and I have only had to lightly scrape off a little bit of build up twice in 2.5 years.
    JoshU's Avatar
    New Orleans, LA
    543
    Re: Dual SWCG setup
    Certainly possible to do. AutoPilot offers a pre plumbed dual cell manifold that would handle this without any modification. It uses CC-15 commercial cells so cell life would very good.
    Only thing you need to watch is that you don't over chlorinate
    How many gallons is the pool? What is your desired run time?
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Jul 2007
    Brisbane, Australia
    874
    Re: Dual SWCG setup
    Quote Originally Posted by ComputerGuyInNOLA
    i think the only real benefit would be the ability to use one while other is broken.
    the rest of benefits would be offset by the cost of second unit
    you would have fewer cleaning, but then you will need to clean two cells instead of one
    they will last longer, but again when time comes you will have to replace two instead of one
    also instead of one unit that could break you now have two, both of which can break
