Thread: Pool Installation Contract
    I have a 19 year old, 27' AGP that needs to be replaced as the walls have rusted through in several places (semi-inground installation). Does anyone have a list of installation requirements that should be included in the installer contract with respect to a "correct" installation?
    19-year old Aqua Leader 27' dia. round. (Soon to be replaced)
    Vinyl liner with center drain
    Hayward Power-Flo Matrix 1-HP pump with Microprocessor Control/Timer
    Hayward Perflex Extended Cycle D.E. Filtration system
    Hayward CL-220 Automatic Chlorine Feeder
    Oct 2012
    Central Ohio
    180
    Re: Pool Installation Contract
    What brand and size of pool?
    Rob
    Cozumel AGP 24' 14,700 gallons
    Pentair Dynamo 1.5 hp pump
    Sta-rite Cristol-Flo II 2.3sq.ft. sand filter
    SWCG,Uni-bead liner
    Borates
    TF-100 Testkit....$68,cheap insurance for a trouble free pool season
    The existing pool is set into a slope..quite honestly I'm shocked we got 19+ years of use without replacing the liner. I custom built the deck to fit the pool which now limits the replacement to a similarly configured model with 19 uprights. The walls have rusted through in several spots which would be expected on a pool this old that is backfilled. The Great Escape (a local chain) says they have one remaining Wilbar pool with the same configuration (27' dia with 19 uprights) which would minimize reconfiguring the deck. My two options are the Wilbar (using their installer) or a Radiant Metric which I like because of the ease of installation if I DIY.
    Oct 2012
    Central Ohio
    180
    I would start with what the manufacture requires for a semi-inground installation for warranty purposes.Most pool manufacturers will only let you bury an above ground pool X amount of inches with proper drainage and back fill.Have your retailer provide you with the appropriate manufacturer guidelines in writing.It all boils down to the manufactures Warranty.
    Rob
    SWCG,Uni-bead liner
    Borates
