Thread: replacing with an Intelliflow VF
    I am getting ready to replace my wisperflow with an Intelliflow VF. the contractor was looking for specifics about the wiring, pentair manual is vague. They say to put it on a dedicated circuit but give no details beyond needing 230 v. does anyone have some specific criteria for this job?
    AG 4000 gal.13' round Louisburg(cedar sides,top rails) Vinyl liner commercial Watsu pool
    indoor, 96 degree, AutoPilot digital salt chlorinator, Chemtrol 250 automated controler
    CarefreeClearwater ion generator, Mecomatic acid feed, Whisperflo WFE-4 1 h.p. pump
    Pentair Master temp 250 HD gas heater, Pentair CC200 filter
    Re: replacing with an Intelliflow VF
    You ought to have a 20 amp, 2 pole, 230 volt circuit breaker dedicated to the pump.
    May 2011
    Orange County, CA
    696
    What Jason said. In addition, it should be on a GFCI protected circuit. 20A 220V GFCI breakers are not cheap, but this is a small price to pay for safety and ensuring the installation is code compliant.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    mas985's Avatar
    Pleasanton, CA
    11,741
    I would also recommend surge/lightning protection. There have been several reports of Intelliflo drives failing due to power surges and/or lightning strikes.
    Mark
    thank you for the input
