Thread: First TF100 test..
    Jun 2012
    Escondido, CA.
    42
    First TF100 test..
    I got my new test kit Saturday and went out and performed the daily quick test.. and got unexpected results.
    My pH was 8.2 and my chlorine didn't even register.. of course the surface temp of the water is 39deg and its been raining off and on here for a few weeks now.
    See any problems?
    I'll do a more in depth test later.. I'm still using a "Pool Guy".. so its on him to fix
    Escondido Ca [*]~23000 gallon plaster pool built in the 70's[*]Pentair VF Pump running 10hrs at 1800rpm getting and estimated 35-40 GPM thruput[*]Sta-Rite Cartridge filter
    Jun 2012
    Escondido, CA.
    42
    Re: Should I be worried with PH levelsin cold water?
    Most pools most of the time can be left alone over the winter, ie no PH adjustments. .......
    However, it is important to be aware that the PH shifts up naturally as the water gets colder, so you do not want to adjust the PH nearly as low as you normally would. If the water is down around freezing you want the PH as much as 0.4 higher ........
    Ha.. I tested (chlorine and pH quick test) my pool (for the first time myself) this weekend and found my pH to be up at 8.2... but its been raining AND the water temp is 39deg.. but subtracting out the.4 for cold water brings my pH right back within normal levels...
    Re: First TF100 test..
    The PH tends to be higher when the water is cold, and that is usually fine. The one tricky aspect here is that the standard PH test will report any PH over 8.2 as 8.2. If your PH is 8.2, then fine, but if it is a lot higher that could be a problem. Unless you have fresh plaster in the last four or five months I wouldn't worry about the PH.
    Chlorine at zero is normal when the pool is winterized/covered, but you don't want it to be zero if the pool is being kept open over the winter.
    38,475
    Also make sure your pump is run at least an hour before you take the water sample to ensure that the water is sufficiently mixed.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by BitViper
    Be aware that the ph tests reads everything above 8.2 as 8.2, so you could be higher. Probably not an issue, but just thought I would mention it to you.
    EDIT: just saw JasonLion responded the same thing in your thread. It would be helpful if you keep you questions/comments relating to your post in your post
    Topics merged. JasonLion
