Thread: pool wall foam
    Sep 2007
    middle tennessee
    38
    pool wall foam
    Need help..Does any know where i can purchase 85 ft long x 52 inch tall above ground pool wall foam?...all i can find is 48 inch tall.....Thanks
    Above ground 24'round-vinyl-14,000 gal,,1 speed-2 hp pump, 250 lb sand filter ..heated,,salted,,lighted,,decked,,with slide and pool rover jr.....
    TFP 100,,am doing the BBB thing...Wet is Wild!
    Oct 2012
    Central Ohio
    180
    Re: pool wall foam
    ? Is it for your.52" pool? If so 48" should work.I have a roll of 48"X85' if you live close to me I'd give it to you.
    Rob
    Cozumel AGP 24' 14,700 gallons
    Pentair Dynamo 1.5 hp pump
    Sta-rite Cristol-Flo II 2.3sq.ft. sand filter
    SWCG,Uni-bead liner
    Borates
    TF-100 Testkit....$68,cheap insurance for a trouble free pool season
    Sep 2007
    middle tennessee
    38
    Re: pool wall foam
    Thanks for reply and offer ..little far from you..I quess after i put foam pad on floor and wall cove foam 48' might just work..Thanks
