Results 1 to 10 of 10
Thread: Any have a Pac-Fab SuperFlow filter?
    buzzbait00's Avatar
    Aug 2007
    North Alabama
    75
    Do ya have the manual?Know how far up to fill wit sand?
    36x18,MAYBE 27000gal?,VINYL.3/4 HP,PAC-FAB SUPER FLO SAND FILTER
    The basic procedure is:
    1. Before pouring sand into filter, look inside and check internal assembly for broken or loose laterals. Replace if necessary.
    2. To eliminate stress on laterals fill tank half-full of water before loadin sand.
    3. When full, top of sand bed should be about XXXXX.
    4. Wash all sand and dirt away from rim/cord ring sealing area.
    5. Assemble filter according to instructions.
    The tricky part is in step 3. The measurement for proper sand height is different for every filter and I don't know what it should be for yours.
    Guest
    Check the Pentair website or contact Pentair. Pacfab is one of their older brand names.
    buzzbait00's Avatar
    Aug 2007
    North Alabama
    75
    Well....since the laterals seem to be ok and I double cheak the multi-valve gasket and its good....Wouldn't have to be low sand?
    The sand could have gotten channelized. Over time paths can form through the sand that allow water to get through without being filtered.
    buzzbait00's Avatar
    Aug 2007
    North Alabama
    75
    I took out the sand and put it back in to look at the laterals.Cheaked the multi-valve gasket.
    buzzbait00's Avatar
    Aug 2007
    North Alabama
    75
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by waterbear
    BB, were you able to contact Pentair?
    You're done SLAMing when:
    buzzbait00's Avatar
    Aug 2007
    North Alabama
    75
    Looked through the web-site.No luck.Guess I'll spend some time on the phone!
    buzzbait00's Avatar
    Aug 2007
    North Alabama
    75
    Re:
    Quote Originally Posted by buzzbait00
    No luck on the phone!
    Anybody have a Pac-Fab SuperFlow sand filter?
