Thread: Added Ascorbic Acid can I add Salt now
    Masspools's Avatar
    Jan 2013
    Cambridge Massachusetts
    35
    Hi All
    I have Salt water pool that have drained new added new water. The bottom had mineral stains so I added ascorbic acid, it is slow to clear the 22,500 gallon because the pool is at 53 degrees.(is this right, I have the heater running to bring it up?) Is it ok if I dump the 12 50lb bags of salt in the pool and not run the salt generator? I want it to dissolve the salt and have it prepared so that I can run the system after the process is done. Your thoughts....
    Masspools's Avatar
    Jan 2013
    35
    Re: Added Ascorbic Acid can I add Salt now
    I guess the simple form of question, will the salt add chlorine or raise the chlorine level, without the generator running?
    As long as you leave the SWG off, or set to 0%, you can go ahead and add salt.
    Masspools's Avatar
    Jan 2013
    35
    I'm slowly building a better knowledge base with you people, Thank you Jason
    Oct 2012
    209
    The salt will not add chlorine as long as the generator is not running. You will need to use liquid chlorine at this point anyway, because of the water temp.
    24' round above ground, 13500 gallons, vinyl liner, 18" Sand Filter
