Results 1 to 10 of 10
Thread: DIY in metal or have built in stone?
    Guest
    We are starting plans for a pool, landscaping and outdoor kitchen.
    I am pretty handy and wondering if building my own with metal frames (not sure if we get the metal studs here in Toronto) or should I get the landscaper to build it with stone?
    Riles_J's Avatar
    Nashville, TN
    218
    Re: DIY in metal or have built in stone?
    If you are fairly handy then doing an outdoor kitchen yourself shouldn't be a bid deal. I constructed mine with no prior experience. Guess it just depends on your budget and how much time you have. There is a wealth on info here and at BBQ Source Forums to assist you if you decide to DIY.
    Riles
    16x32 IG vinyl, 19,000 gal, 1.0 hp pump, sand filter, 2 returns, 1 skimmer, diving board, slide
    Aug 2010
    New Caney, TX 77357
    184
    I would second what Riles said. I built mine by myself and got most of the how-to info from simply reading this forum and a little from BBQ Source Forums. I really didn't solicit much help online (I got some stucco suggestions from Riles) and got through it successfully even though there were a lot of "firsts" for me on that project - first time working with metal studs, first time installing tile, first time working with stucco and probably some others I am not recalling at the moment. I had never attempted anything remotely comparable to that project and although it took me quite a while to finish, the satisfaction level was very high when I could look at it and say "I built that!".
    20K gal, inground with attached spa, pebblefina plaster (bella blue), flagstone coping, moss rock waterfall, Sundek - Indian wheat, (2) Jandy PHPM2.0 (filter pump and waterfall), Jandy DEV60 DE filter, Polaris 280 pool cleaner, Polaris Halcyon PB4-60Q booster pump, Polaris 1.5 HP Air Blower, (2) Jandy WaterColors LED lights, Jandy LXI400P Heater, Jandy AquaPure PLC1400 SWG, Jandy AquaLink RS PureLink Controller and PDA.
    4knights's Avatar
    NE Kansas
    419
    I will third what the others said, I'm planning my outdoor kitchen right now and there are literally thousands of designs out there. I didn't want to pay for a design plan, so I watched a few hours of YouTube videos on different designs with and without pergola overhead and the ideas I liked I jotted down on paper and copied the photos for reference.
    Local big box store wanted a fortune for the metal studs so I stopped at a demolition job being done near the mall. They were throwing out a dumpster full of metal studs! I asked the foreman if I could do some dumpster diving and he said NO but he'd have his guys leave all the rest of the straight ones in a pile beside the dumpster. Now I have about 60- 8 ft long studs for when I'm ready to start the project and all I need to buy is the screws.
    The hard part is figuring exact dimensions for your grill, sink, etc so when you get ready for the backer board it all fits.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Guest
    Where can I get metal studs in Toronto?
    4knights's Avatar
    NE Kansas
    419
    Check with any of the local commercial builders or local inspection department. They should know where you could get them or at least the inspection department could tell you of any builders using them.
    Aug 2010
    New Caney, TX 77357
    184
    Quote Originally Posted by Shaf77
    You have Lowes and Home Depot in Toronto. It looks like they carry metal studs at your Home Depot stores there at least. Check with your local store(s) because if like in the USA not all stores carry the same products.
    Guest
    In terms of cost and durability, which one is a better option from building an island with stone sides instead of metal, board and then tiling?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Not sure I understand your question. Are you talking about building the island itself out of mortared stone vs. studs/cement board? Most islands aren't build out of stone, like a castle, rather, they're a stone veneer applied over either stacked concrete block or a metal frame/cement board, same as tile or stucco. Building it out of concrete block is going to be cheaper, but it's not as versatile. If you like the stone look, I'd suggest a metal frame, cement board, lath, and then stone veneer.
    Guest
    Quote Originally Posted by Melt In The Sun
    Thanks for clarifying. That's what I meant.
    Choosing between mortared stone vs. studs/cement board.
    I am concerned more about the water and weather here in Toronto.
    When you say using blocks is not as versatile, what do you mean? How so?
