Results 1 to 7 of 7
Thread: Landscaping programs?
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    Does anyone know if there are any free or low cost landscaping programs available online? I really want to start planning the next phase putting the backyard back together!
    TYIA
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    Butterfly's Avatar
    South Carolina
    10,045
    You could try Google's SketchUp.com
    They have a FREE version
    You're done SLAMing when:
    May 2008
    SE Michigan
    38
    I'm not sure how low is low cost but I use Home Designer Suite and now the Pro version from here.
    http://www.homedesignersoftware.com/
    They have a landscape program. The Home Designer Pro I use is a very good program, but there is a learning curve (you won't be printing in 10 minutes). They have a good forum to ask questions.
    Skinman
    Skinman
    16 x 32 Doughboy AGP
    Doughboy 17" AquaView sand filter
    1 HP, 2 Spd. pump
    (4) 2 x 20 Sunheater Solar Heat
    Solar cover w/reel
    TF 100 Test Kit
    May 2008
    SE Michigan
    38
    lulupalooza,
    I should add that there is a lot to the program that I use. It takes a while to get the hang of it (a week or more?). It also takes a pretty beefy computer to make it run well. You could read through the forum there to get an idea of what you're up against.
    I don't know how to get your house in the Landscape Designer. I use the package that has the home, landscape and everything design. You can get a few bucks off on some of the software at Amazon.
    Good Luck
    Skinman
    1 HP, 2 Spd. pump
    Solar cover w/reel
    TF 100 Test Kit
    I have nothing to add, except there is another thread I started on this topic not too long ago... I looked at sketchUp and decided the learning curve was too high for me... I went with pencil and paper - instant results!!!
    ETA link
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Mar 2008
    Central VA
    328
    Tell you what we did ... I got one of those programs, but I just didn't have time to learn it (busy at work)...so, we went to a local garden center (a dealer not a big box) and they agreed to have one of their on-site gurus suggest plants for us. I had to give them pics. of the house and a drawing on graph paper, but they filled it in with plant suggestions and it turned out really nice (in the front, I still have to do my pool area - arrrr).
    Todd
    Pool: 16x36, 16,800 gal., vinyl, sand filter, SWG & AquaCal Heat Pump
    Spa: Hot Springs Sovereign, 355 gal., ozone/ion
    The most helpful tool you'll ever have for your pool:
    http://www.poolcalculator.com/
    May 2008
    florida
    112
    Re: Landscaping programs?
    There is one that I got from the libruary that is called Landscape Designer and very easy to use. You can also use it for your home once you know how. Don't think it is sold anymore but when it was it was only $10 - 20 and I didn't buy it.
