Thread: Peristaltic pump vs SWG - which way to go?
    Jul 2011
    Austin, Texas
    78
    I live in Austin, Texas. I've been using BBB for almost two years. Summer is glorious minus the daily worship of adding chlorine. In the wintertime, I cover my pool with netting to keep the leaves out. Last year, I fired up the built-in tablet chlorine dispenser to keep algae at bay until I reopen the pool around April. This year, the tabs didn't do the job and I have a swamp to deal with.
    I'm ready for some better automation.
    I will go with either SWG or chlorine injection. I read up on the Liquidator two years ago and now it seems that the peristaltic pump is the new thing, right? Please help me to make a decision. Here are the facts:
    • 1. I will install either method myself
      2. In ground, plaster, 30,000 gallon built in the 90's
      3. Money is not the top concern, my budget is flexible. I would not go over $2,000 but I'd really like to be at $1,000 or less.
      4. No rock to worry about, just ceramic and concrete. No metal in the pool (old style ladders or such)
      5. I do not currently have any electronics. I have just the old fashion mechanical timer.
      6. pool gets direct sun for about 5-6 hours per day in the summer
      7. runs a Polaris if that matters
    Thank you, TFP community!!
    30K IG, Plaster with spillover spa, 9 ft deep end with spring base diving board
    48sqft DE Filter, 3HP VS motor, Hayward SPII, Raypak RP2100 Propane heater
    AutoPilot Pool Pilot Digital with SC-60 and pump relay (220v)
    Polaris 280. Pentiar Booster Pump, TF-100 Test Kit, Speed Stir
    Austin, Texas (It's hot)
    Feb 2008
    Denton, TX
    5,061
    Re: Peristaltic pump vs SWG - which way to go?
    My choice would be the SWCG over the Liquidator.
    Jul 2011
    Austin, Texas
    78
    Sorry to be dumb but, is a SWCG the same as a SWG?
    Jun 2011
    Long Beach, CA
    2,790
    Quote Originally Posted by Technigogo
    Yes, both are used as shortcuts for Saltwater Chlorine Generator.
    22,553
    At 30,000 gallons the LQ (liquidator) is going to have to be refilled every week or so, and you'll be running it near wide open to get enough chlorine into the pool, so I wouldn't recommend it.
    Since you have no stone/metal to worry about either a swcg or an injection pump will work great for you. Either one of those will work on a simple timer also.
