Thread: Pump wet end complete unit replacement
    Hello all,
    I have a three-phase A.O. Smith Centurion 56y motor, and plan to use it with a Lenze Ethernet-enabled 2phase to 3phase variable speed drive controller. Since I appear to have the electrical drive portion of the pumping station addressed, I have been looking around for a complete wet end with a basket. I can't seem to find anything- anyone have any ideas or suggestions? It is a 2hp, and I am plumbing 3" lines.
    Thanks in advance!
    22,553
    Re: Pump wet end complete unit replacement
    You're most likely going to have to come up with a pump that uses a 56Y frame motor and just order the wet end as replacement parts. Given that, it may be cheaper to buy a complete pump and just replace the motor.
    EDIT: The Pentair Whisperflo uses a 56Y frame motor.
    Thanks a million- when I cross referenced which pump assemblies used this motor, the whisper flow came up- I have been hitting eBay for the past month looking for a complete wet end, but have had no luck. I'm a newbie to this, so I figured I was doing something wrong. Thanks for confirming how to get this, looks like it will be $$$!
    It will be a few months before I need it, perhaps I'll get lucky and find one with a blown controller or motor that someone wants to offload.
    Cheers
    22,553
    I'd check Craigslist. You might get lucky.
