Thread: Versa Heater Makes Knocking Noise, Then Trips
    I have an older Versa heater, and when I turn it on, everything seems to be working, then after about 3-4 minutes, it makes a knocking banging sound, then the "High Limit" light comes on.
    Any idea what's going on?
    Thanks for the help.
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Re: Versa Heater Makes Knocking Noise, Then Trips
    Quote Originally Posted by jacob_coulter
    Maybe low water flow ~ http://www.troublefreepool.com/heate...ter%20clanking
    Dave My Pool Build, ODK Build
    22X42 Gunite Freeform 23K Gal, 10X12 Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
    Mar 2011
    441
    The versa heaters have a part called a unitherm governor they regulate the water flow through the heater to prevent condensation. If/when they fail they can obstruct the water flow causing the water to boil inside the heater. What model of versa is this?
    20X40 30,000 gallon gunite pool
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Quote Originally Posted by pragmatic
    That thread also suggests a UG (BY Racket incidentally)
    If i does it only briefly during start up, the UG could be just sticking from scale. If you replace it, you should be good.
    Factory Warranty Station for:
    Thanks for the help, much appreciated.
    When I was getting some pool work done, I had a tech look at my heater and he said it was due to the spa pump having a bad impeller (which it did) he said everything would be fine once I replaced the pump (which I did) now I have this issue.
    Is a Unitherm Governor something a DIY'er can handle, or is that best left to a technician? Any recommendations online on where to buy the part?
    Also, any reason why they are so expensive when they look EXACTLY like an $8 automotive thermostat?
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    The uni-therm governor is located just under the header, where the water enters and exits the heater. You should be able to access it pretty easily if things aren't rusted over. They are expensive becasue they have the Raypak name on them.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
