Thread: Intex SWG conversion to standard AG
    my wife and I have had an Intex 16x48 for 2 years and bought intex swg last year and just love it. We want to get a regular AG this year. Can I use the Intex SWG with any regular AG? Or will the size of the inlets not be compatible? Any advice would be greatly appreciated.
    24,300 gallons, 18' x 36' IG, plaster. Eight returns; three floor, five wall (including Polaris return). Two skimmers, two main drains. Pentair FNSP48 DE filter. Aqua Heat LS heat pump heater. Coverstar auto cover. Polaris 280 w/booster. Jacuzzi Magnum Force pump. Converted to BBB in 2012.
    38,260
    Re: Intex SWG conversion to standard AG
    Welcome to TFP!!!
    I am not sure exactly how that SWG gets plumbed in (no experience), but would have to think it is possible. Although realize that if you got a larger pool, that SWG may not be large enough.
    You will need plumbing adapters to make the connections. You can purchase them or make them yourself. As long as the new pool isn't too much larger than your current pool it will work just fine.
    Oct 2012
    Central Ohio
    180
    You may want to verify,but if I remember correctly the Intex SWG will handle something like 14,000 gallons of water.That roughly equates to a 24'X 54" pool.I say run it until it dies then buy another SWG.(Compupool,Hayward etc.....)The more water you have the longer your Intex SWG will have to run.14000 gallons of water you may have to run it 7,8 maybe 9 hrs.
    Rob
    Cozumel AGP 24' 14,700 gallons
    Pentair Dynamo 1.5 hp pump
    Sta-rite Cristol-Flo II 2.3sq.ft. sand filter
    SWCG,Uni-bead liner
    Borates
    TF-100 Testkit....$68,cheap insurance for a trouble free pool season
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, producejohn
    I am using the intex swg on my permanent above ground (see my sig). It works great...I used the mod in the thread that JasonLion pointed you too.
    One other thing...if you haven't already, make sure you unplug the connection to the copper bars (last connection in the flow path) on the intex swg...no need to add copper (and it's problems) to your water!
    Thanks for the help, great to be a memeber of TFP
