Results 1 to 7 of 7
Thread: Sta-Rite SR400NA High Temp Reading Turning Off Burner
    Aug 2008
    Roseville, CA
    3
    When starting heater, display shows 180, r4 at boot up.
    Have set both the pool and spa to 104 degrees max temp, through the control board procedure.
    The blower turns on and after factory delay the burner fires up. Operates as it normally would when things where tuned.
    During start up, my temp starts in the high 80's, low 90's and fluctuates +- 3 to 4 degrees continuously (pool/spa temp is actually 56 degrees currently)
    Once burner starts, temp will start to rise, continually fluctuating, until within a couple of minutes it will shut off once the temp reads 106.
    At this point the blower will stay on for the factory specified time if the temp stays at, or above 106. During this time frame, the temp display will continue to rise until is maxes out at 112 and it will fluctuate between 110 and 112 even with the blower shut down and the pool/spa temp in the mid 50's.
    I shut down system and breakers for 5 mins., cleaned interior, checked for loose, or dirty connections. Dialed the water pressure switch to be a bit more generous toward a lower pressure (heater is within 5ft. above the pool/spa water level.
    System appears to operate as designed and will fire up blower and burner if temp stays below 104, just can't figure out what switch/relay is throwing the erroneous temps?
    Any guidance will be greatly appreciated as this polar bear spa thing isn't doing it!!!!
    Inground Plaster 25,000 Gal. StaRite S8M150 Cartridge Filter. 1 Hp StaRite Max-E-Glas Pump. Spa attached to pool. Polaris 280 w/ 3/4 Hp Booster. StaRite Max-E-Therm 400k natural gas heater
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Re: Sta-Rite SR400NA High Temp Reading Turning Off Burner
    The Temp sensor has probably burst, and needs to be replaced. It is relatively easy to replace. If you (still) have your owners manual, you can find the sensor's location, and perform the replacement.
    Factory Warranty Station for:
    Mar 2011
    441
    Does the temperature read in the 50's before is fires up?
    20X40 30,000 gallon gunite pool
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    When you are done with the repair, you should put the pressure switch setting back where it was. Those should only be adjusted in the case of the heater being below or above the pools' water level. And even then only need to be adjusted very little. There is no benefit from adjustment when closer to waters edge.
    Aug 2008
    Roseville, CA
    3
    No the temp starts in the high 80's right after boot up.
    I'm assuming the temp sensor is called the "Thermistor"? Looking at the parts schematic and not a one for one match?
    Got it on the water pressure switch. Thanks for the guidance and also thanks for timely replies.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Yes, thermistor = temp sensor
    Aug 2008
    Roseville, CA
    3
    That did the trick!!! Replaced Thermistor and now I get a constant temp. that reflects the pool/spa's actual temp. Thanks again for the help.
