Results 1 to 12 of 12
Thread: Muriatic Acid: Where to buy
    mnittler's Avatar
    Sep 2012
    South Texas
    58
    Where do you all purchase Muriatic Acid? Are there different grades/quality?
    I have a salt water in-ground pool and figure that I will be needing plenty of it when the builder turns the pool over to me in 30 days.
    I also installed the Pentair IntelliPh system but have not turned it on yet.
    21,500 gal sport pool, 8' spa, beach, 400k btu LP heater, Pentair IC60 SWG & #300 Tablet Feeder, 60 sqft DE filter, Paramount in-floor PoolValet 3 cleaners, Debris Canister, Polaris 360, Pentair VFD 3hp pump, IntelliPh, Geysers & Turbo Twister Slide w/1 hp pump, Color LED Pool & Spa lights, E-Z Touch8 control system, Wireless controller. Test Kits:TF-100, Taylor K-1004, CYA K-1720, Phosphate K-1106, Salt Water K-1766, Hach CN-39WR.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Muriatic Acid: Where to buy
    Hello,
    I get mine from Home Depot, 2 - 1 gal containers about $11. Stored out side. Full strength is 31.5% or so.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I get mine at Lowe's or a farm store. Home Depot doesn't carry the real stuff around here.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Beware of the splashless kind it is weaker and doesn't work as well. Hardware stores, paint or concrete aisle usually.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    jjslinger's Avatar
    Sep 2011
    Santa Rosa, CA
    97
    At a local hardware store in the paint section, I can get a single gallon of 31% for $7.25; outside in the garden section they have 2-packs of a different brand for $11. The local Home Depot here only has some kind called "Safer" muriatic acid, I can't figure out what it is so I don't buy it.
    16K gal IG 16'x28' pebble since 2011; Pentair Easytouch; Sta-Rite Intellipro VS pump; Sta-Rite 400 sq. ft. cartridge (System 3); 6 Heliocol Solar Panels; Aquamatic Cover; Legend pressure-side cleaner with Hayward booster pump; TF100 Test Kit.
    Mike_W's Avatar
    Aug 2011
    Orange County, California
    142
    Quote Originally Posted by jjslinger
    The claim is that the safer acid has less fumes. According to the MSDS (Material Safety Data Sheet) on the HD website, "Safer" muriatic acid is less than 25% concentration. The rest is likely to be water. So compared to the normal pool acid (at 31.5%), I guess it is a bit “safer” - but that does not mean it is safe and it still needs to be handled with the normal precautions. A gallon of the safer stuff is listed at $7.27 where as 2 gallons of the 31.5% is around 11 dollars.
    Mike
    ~17' x 34' IG pool with attached spa - 20500 gallons - Gunite with a "pebblesheen"-ish finish
    Jandy iAqualink with iPad and Jandy PDA remote - Pentair IntelliFlo VS 11018 Pump
    AquaRite SWCG - Pentair SMBW 4060 DE Filter - Really Old Raypak heater
    "Wall-E" an Arneson-Hayward Navigator - A couple of Jandy/Zodiac WaterColors LED Lights - Blue-White F-1000 Flow meter
    jjslinger's Avatar
    Sep 2011
    Santa Rosa, CA
    97
    Quote Originally Posted by Mike_W
    Mike
    Thanks Mike. The "Safer" stuff did not have any concentration info on the bottle itself, and I was too lazy to look up the MSDS.
    I should also mention that a chemical store around here sells 4-packs of the 31%; you have to return the bottles for reuse. I see this in the trucks of all the local pool maintenance guys. I think it's a bit cheaper than the 2-packs for $11, but I don't want to store that much muriatic acid, so I pay a little more for the smaller quantities.
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    Got mines at Walmart paint section but don't have any % on it. No sure if this was the right one too get.
    6280 Gal Intex 17' x 52" Metal Frame AG
    2500 GPH Filter Pump
    Intex Krystal clear SWG
    Taylor K-2005 With FAS-DPD Drop TEST KIT And Speedstir
    Intex Robot Pool Cleaner
    Apr 2011
    Murrieta, CA
    2,360
    It's Hydrochloric acid {Hydrogen chloride} 20.0 % according to the MSDS: http://www.kleanstrip.com/uploads/do..._Acid_MSDS.pdf
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Ive been using the Kleen Strip but just saw that Lowes has 31% gals for $3:65
    it will be my next stop
    Shop Crown 1-Gallon Muriatic Acid at Lowes.com
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Lowes is my go to place for acid. Blue label in the paint section is the good stuff.
    Support the site
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    Just got this from Lowes couldn't find any that says 31%
    Quote Originally Posted by EVChargeGuy View Post
    Didn't see that at lowes at all got this 026452002201.jpg it's 31% to 35% Hydrochloric acid {Hydrogen chloride}
    http://www.jasco-help.com/uploads/ge...MA220_MSDS.pdf
