Results 1 to 18 of 18
Thread: No more trees...Now pool gets too hot.
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    890
    Any ideas on Man Made Shade for an above ground Pool? We used to have trees...big ones 85 feet or taller on the east...neighbors got a pool and they all got cut down. Now my pool topped out at 96 degrees last summer and it wasn't even fun to get in it. Does anyone have any ideas for man made shade for a pool that doesn't involve replanting a tree on my side of the fence? I can't stand when the water is warmer than the air temp...and the air is 87 degrees.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    Re: No more trees...Now pool gets too hot.
    You can build a pergola.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    I know some on here have used fountains (homemade or store bought) to cool the water down. Once I get around to hard plumbing my pool I plan on putting an old adjustable shower head and valve on a Tee above the return.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    http://www.mistcooling.com makes an adaptable inlet fitting that creates a mist
    you run at night. I have two customers that reported a drop in temperature of 6-10 degrees using it.
    Christian's Avatar
    Jul 2012
    Sacramento, California
    304
    Anything that aerates the water at night will help. Fountain, waterfall, etc.
    Christian's Avatar
    Jul 2012
    304
    You could also go with a heat pump that has a cooling option though that can get expensive.
    30,133
    a-cheap-pool-cooler-for-the-end-of-summer-t2501.html?hilit=pool%20cooler
    This is just one of many threads on this forum using aeration as the cooling process. They work day and night and can be built VERY cheap.
    there you go, a perfect solution!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,127
    Aeration definitely helps. 3-4 degrees is easy to cool with a simple sprayer made out of 1-1/2" PVC and a few fittings.
    You could also look into a sail-shade. This past summer was exceptional though, so you may want to see what a normal year is like before committing to an expense.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Solar heaters but run them thru the night instead of thru the day.
    6 different good solutions in 3 hours. Pretty impressive response!
    X-PertPool's Avatar
    Exeter, PA
    1,385
    You can also do some geothermal plumbing. The ground is always around 55 degrees so if you run coils of pipe in the ground and push water through it into the pool. Kinda like running the solar panels at night except the temperature of the ground is always a constant.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Feb 2008
    Northwest Indiana
    890
    Quote Originally Posted by X-PertPool
    So thats why my 100 lb Newfie always digs a hole to lay in duting the summer...we just thought she liked being dirty!!!
    Beave
    Oct 2012
    Houston, TX
    186
    I have a 12' diameter offset umbrella. I got it so that I would have a shaded portion of the pool to float in. It shades a nice section of the surface but also keeps the late afternoon West sun off a bit of the side of the pool. I leave it open 24/7 thru the summer. It makes a difference!
    Intex UltraFrame 14'x48in - 3,900 gallons. Intex 1600 GPH combo Sand Filter/SWG Hard Plumbed w/Hayward skimmer, suction & return. Borates.
    And... 15k gallon kidney shaped gunite 1975 vintage. Hayward DE3620 filter + Hayward 750 pump.
    TF100 Test Kit | Pool School | Pool Math
    DaneCE's Avatar
    Jul 2011
    VA
    241
    Jul 2012
    Canada, Ontario
    6
    Sail shade is amazing, I installed one on our deck that was under sun till 6-7pm and we could not enjoy it, after the installation I was more than surprised on the outcome
    Intex 18x52 salt water (SOLD)
    A friend in Galveston has a fountain that attaches to a return. It does a great job of cooling the pool. Swivels, can be raised and lowered, adjustable height of spray. Just noticed it at Warehouse Pool Supply for $25.
    I am curious if this reflective bubble wrap would work to keep a pool cool:
    http://www.lowes.com/pd_13357-56291-BP24025_0__
