Results 1 to 8 of 8
Thread: What causes CH to rise?
    phalcon51's Avatar
    Oct 2010
    So. California
    203
    Hi all,
    I'm having a problem with high CH levels and I'm wondering what causes it to rise over time. The level was at 250 ppm in early January, 2011 and then started rising in mid-March. Between April, 2011 and June, 2012 it rose from 270 ppm to 575 ppm. It's now up to 675 ppm and I'm in the process today of draining and replacing a large portion of the pool water. The CH of my fill water is 160 ppm.
    So, my question is, how can I prevent this from happening in the future? I've been using the BBB method (without any Borax yet) and the Pool Calculator set to TFP Goals since the pool was first filled after re-plastering in September, 2010. Could the curing plaster have contributed to the increasing CH levels? We are running an SWCG but I need to add bleach in the winter months when the water temp drops.
    Here are the results from the latest test (Using Taylor Complete FAS-DPD test kit from Leslie's)
    Pool Volume - 26,200 gal.
    FC - 3.5
    PH - 7.5
    TA - 60
    CH - 675
    CYA - 60
    Salt - 3800
    Temp - 50f
    Any help or advice appreciated.
    Gary
    26,200 gal. 35' x 16' Plaster IGP (50 yrs. old), Hayward 48 sq. ft. DE filter, Hayward EcoStar VS pump, Intellichlor IC-40 SWCG, The Pool Cleaner 4X suction, Pool Skim and Pool Devil skimmers. Re-plastered Sept. 2010.
    30,426
    Re: What causes CH to rise?
    1. Even if your fill water is low in CH, CH will continue to rise through refill and evaporation.....you add more when you refill but it doesn't come out when it evaporates.
    2. The only solution is to do a partial drain and refill
    3. What is the CH of your fill water?
    phalcon51's Avatar
    Oct 2010
    So. California
    203
    As noted in my original post, fill water CH is 160 ppm. Is it ok to just leave it at that level and let it rise on it's own, or is that too low? What's the minimum CH I can get away with for semi long-term use?
    Gary
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,042
    Water evaporates, the Calcium in it stays behind. 675 doesn't sound all that high to me - I've gone into 4 figures before!
    You have low TA, so the CSI should be okay. Keep pH at the low end and you shouldn't have any problems. The only solution I have is continuously draining and refilling. I use pool water on the lawn and then refill it with lower CH tap water. I've directed one of the downspouts into the pool, which is a source of Calcium-free water, although it does tend to introduce a lot of very fine silt at the beginning of the storm. Since you run a SWG, I don't know if watering the lawn is feasible. I have no first hand experience with saltwater and grass.
    What type of Chlorine and shock are you using? Those are typically the only way CH rises.
    Quote Originally Posted by PoolsPlusMI
    CH in fill water is the most common cause of CH increasing, though the use of cal hypo for chlorine (which also contains CH) is also a significant cause.
    22,551
    I don't know about MI, but in a part of the rest of the country where the CH out if the tap is in the 400 to 500 range, cal-hypo (while signicant) isn't the major cause of rising CH.
    phalcon51's Avatar
    Oct 2010
    So. California
    203
    I'm using laundry bleach from Wal-Mart (6% sodium hypochlorite) for the chlorine when it's too cold for the SWCG to work and I'm not using any shock at all.
