Page 1 of 3 123 LastLast
Results 1 to 20 of 44
Thread: Ants killed my pump again...replacement ideas?
    Jul 2012
    Georgia
    77
    Well, it happened to me for the second time....ants built a mound into my 1hp pool pump.
    It was tripping the breaker. I cleaned away the mound and got the ants out of the electronics and now I get the dreaded hum, but not starting. I also blasted water into the vent openings to clear out the mud.
    I have executed my "Plan B", and moved the feature pump into position as the filter pump. Out of harms way for now, but I want to consider more a economical main pump, if I cannot fix the one I have pulled out.
    So, 2 questions:
    1. Is my current pump dead? I plan to rip it apart later to see if I can clean out more mud to get it to run.
    2. Leslie's claims the Hayward EcoStar pump saves $1500 in electricity per year. That's $125/month. I read here that it also features freeze protection, which sounds cool. Has anyone tracked their energy savings from this pump? Cost is $1300 at Leslie's.
    19k gal, STS1072R A.O. Smith C-Face Motor .75HP Full-Rated 2-Speed, Hayward Sand Filter
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Ants killed my pump again...replacement ideas?
    How high are your electric rates? My total electric bill (which includes air conditioning a 2700 square foot house in Tucson AZ) averages around $180/month. I doubt it would go down to $55 if I bought a new pool pump.
    I figure my pool pumps consume about $40/month at the height of the swim season, even less during other months, and that's for old single speed units.
    chiefwej
    22,551
    1) You won't know if it's ruined until you takes the back cover off and see what's wrong in there.
    2) Unless you live in one of the few places where the electric rate is very high, had a very large hp single speed pump that you were replacing and ran it 24 hours a day, you're not going to see nearly that much savings. My big ole single speed pump on;y costs me about $40 per month or less during the swim season to run, so no pump could save me $1500 per year. They like to exaggerate the savings with those pumps. While they are good pumps and can save money, you need to be realistic about how much it will really save you.
    Tell us about your pool & equipment and how much electricity costs you.
    Jul 2012
    Georgia
    77
    My electric bill runs a minimum of $125, and runs to a maximum of $300 in coldest winter/warmest summer months.
    So I guess I spend $175 on A/C here in southern Georgia, so pool is certainly less than $60/month.
    GP estimates it is between $26 and $40, using their calculator.
    Can't really turn the pool off for a month to find out exactly the charge.
    Pool is 21000 gals...SWG, pump was 1 hp, now I am back to 3/4 hp using the old feature pump. (Pool company originally used 3/4 for both...replacement last time was with 1 hp, due to lack of 3/4 hp availability.)
    Jul 2012
    Georgia
    77
    Well, no luck getting further into the motor than the impeller removal. Seems like a lot of delicate work needs to be done to get the thing truly apart. I shined a light in and things did not look too bad, although there was a smell of burnt electronics in the motor windings (not from the electronics in the end cap with the magneto.)
    I will let it dry out overnight some more, and install in the morning as the feature pump, to see if it wants to work.
    Based on the input so far, I may just select a standard 3/4 pump again.
    22,551
    Did you pull the back cover off and clean the contacts?
    In south Georgia your electric rate isn't high enough that you'd ever recoup the extra cost of a variable speed pump. Your best bet would be to go with a 2-speed. Either a 3/4th hp full rated or a 1 hp uprated pump would work fine.
    Jul 2012
    Georgia
    77
    Yeah, it's shot. Put it back and at first it buzzed. Turned off and heard a "click" a minute later.
    Tried again, and it ran slowly with a bad grinding sound. So time for a new pump.
    What's the story with the 2 speed pump? Is that a rewiring project as well?
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    It could be a rewiring project, but doesn't have to be. You can get a manual hi/low switch mounted on the back, and keep the wiring as it is.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    There are several good reasons to consider a multi speed or variable speed pump, but they will never pay back the extra cost in a single year. I plan of using one the next time I have to replace a pump, but instant savings isn't my prime reason. Quite operation, better filtration are more important in my decision making. Savings are only achieved over the long term and that is assuming a good long life cycle with no problems.
    chiefwej
    Jul 2012
    Georgia
    77
    I notice the Variable pumps are fully sealed (no vents) and so would have survived an anthill being built against the pump.
    Hey, just wanted to give some more pool info. I have 1.5 inch piping all around, including to and from the Filter.
    The SWG is designed for 2" pipe, so there are 2 special junctions to allow for that transition and back.
    The filter claims to process 75 gpm, but the flow through 1.5 inch piping is only 42 gpm, so I think that is what I have to shoot for. I have 3 return lines and only 2 lines out to the pool, but all branch from the same 1.5 inch central piping.
    So, will a 2 speed filter be able to push enough water? Seems with the variable, you can tweak it to what you need, but I can see buying the 2 speed and having to run it in the higher speed all the time. (saving nothing, and spending 2x on the pump, it appears.)
    Seems if I settle for a single speed motor only, I can get a AO Smith UST1072 Pool Pump Motor with the 56J Frame, and be done with it for only $160. Wonder if the 2-speeds have the 56J frame?
    Guys, what does "up-rated" mean? Doesn't sound good.
    Jul 2012
    Georgia
    77
    Google is your friend...here is the skinny on up-rating:
    The Calculation
    There is one simple calculation which tells the whole story
    Horsepower X Service Factor = Total Brake Horsepower
    If you multiply the horsepower rating times the service factor, you find out the total brake horsepower.
    The total brake horsepower of the pump is real power rating of that pump or motor.
    How Pumps and Motors Get Uprated
    The motor plate above lists the following ratings for this 3/4 HP Full-Rated Motor:
    Horsepower - 0.75 Service Factor - 1.5
    If we insert these factors into the equation, we end up with the following result
    0.75 1.5 1.13
    Now, suppose you really wanted to take this motor and call it a 1.0 HP motor instead.
    You would just INCREASE the Horsepower Rating and DECREASE the Service Factor.
    1.0 1.13 1.13
    VOILA . . . that 3/4 HP Full Rated Motor is now classified as a 1.0 HP Up-Rated Motor
    EXACT SAME MOTOR . . . DIFFERENT HORSEPOWER RATING
    mas985's Avatar
    Pleasanton, CA
    11,741
    We have it well documented on the forum here:
    pool-school/pool_pump_basics
    or here
    hydraulics-101-have-you-lost-your-head-t915.html
    Mark
    Jul 2012
    Georgia
    77
    Thanks for the schooling....I thought about Pool School, but did not think that was in the syllabus.
    Does it matter if my pumps down a hill, 4 feet lower than the pool deck? Does that increase my "head", or is it a wash, since water pressure into my pumps is positive, rather than a vacuum. Which means when my seals fail (happened once in a freeze) I lose an expensive 4 feet of water.
    22,551
    It might make a little difference depending on just how it's situated, but it's most likely not much. The head you gain on the suction side by being lower than the pool is offset by the amount you have to pump the water back up hill to get to the returns.
    Quote Originally Posted by LotusRacerX
    If your equipment is downhill then that is 4feet of vertical head. Honestly is should zero out depending on where the return lines are.
    Seals Fail??
    So what seals failed motor, returns, tablet feeder??
    Jul 2012
    Georgia
    77
    Quote Originally Posted by poolweasel
    Seals Fail??
    Sorry, it was actually a valve freeze/burst, from the floor drain return. I just worry that with ME re-assembling my pumps, I might mess it up and have another water loss situation in the future.
    Are you saying that if there is no leak once re-assembled, it will not start to leak later? That would be comforting.
    With the 2 speed pumps, the top speed is too much for my pipes, at 1.5 hp, and the slow speed of .25hp sounds too low. I am thinking of going with a Full Rated .5 hp unit, which multiplies out to .8hp, while using less power than my current .75 uprated motor.
    Is the return still under water?
    What part of the country do you live?
    I agree with the two speed and not using but, depends if you are replacing the pump or the motor.
    Top speed of any pump is around 3250 rpm
    Variable speed motor can replace any motor.
    A pump as a whole you must get a .(v speed) a two speeds top speed has to be a tad lower.
    22,551
    There's no guarantee that a pump won't leak later but that's true even with a brand new pump. The chance of it happening is really low. Once you get it all reassembled and it has ran for a little while, if there are no leaks, then there's a very good chance that there won't be until the unit wears out again, and that will be along time.
    Replace the motor/pump with a 2-speed model. The high speed will be the same as you have now and the low speed won't be too low. When you reduce the speed of the pump you also reduce the head losses and therefore a very small hp will turn the impeller. Even though it seems like a very small hp on low it's designed to operate that way and be fine with it.
    Actually top speed is about 3450 but that doesn't matter anyway.
    A variable speed motor can only replace a motor with the same frame size and rated for the same hp or less. Also if you replace the motor with a variable speed motor you're going to have to have a controller also.
    I don't know what poolweasel is trying to say in the last sentence, but as I said, in south Georgia a variable speed pump will never pay for itself. Now if you just want one for the "coolness" factor that's a different animal and it certainly will work for you.
    Jul 2012
    Georgia
    77
    OK, I got it down to 2 contenders:
    AO Smith ST1052 1/2 hp, 1.6 sf 5.3 amps at 230v
    AO Smith B977 2-speed 1.3 sf 1/4 hp 3.1 amp/1.5 hp 8.9 amp
    My thought is that the single speed is the "safe choice", will definitely work. Essentially the same as my 3/4 hp uprated motor with its 1.0 sf. Slightly less amps, and 1/3 less amps than the 1hp unit that just blew up.
    I am willing to trust that the 2-speed will move some water at 1/4 hp * 1.3 = 1/3 hp
    What I am worried about is that when run at the higher speed (1.5 hp * 1.3 = 2 hp), it will be too much for my skinny 1.5 inch pipes. Is this really not a concern?
    If they all spin at 3450 rpm, then how are the higher powered units providing more flow exactly? Or would a unit that is too low powered simply buzz and not turn at all?
  20. Back To Top    #20
    38,305
    You should match the high speed HP and SF to your existing pump and ignore the low speed parameters ... Assuming you are not replacing the pump and only the motor. There are certainly smaller 2 speed pumps available.
    The impellers are different depending on the HP, so they move more water. If the motor HP is too small for the impeller, you will shorten the life of the motor and it may overheat. A larger motor will be fine on a smaller impeller, but costs more for the same performance.
    Posted from my Droid with Tapatalk ... sorry if my response is short
