Thread: New to forum and BBB
    Jan 2011
    Gilbert, AZ
    6
    Hey everyone...I am a fairly new pool owner (about 2 years). It has definitely been an experience and I have learned a lot thanks to this site (been lurking for quite some time). I have just recently switched to the BBB method from the tabs. My new test kit (TF100) will be here this next week and I am excited to look at some readings besides FC and PH that I've been doing up until now. I also started getting the refillable hasa chlorine bottles from a local pool store for (.21/scl) my bleach method. I will post some pictures as I get my yard more cleaned up but I look forward to learning more and asking lots of questions and maybe even answering some once I get more proficient at this crazy thing called "pool ownership."
    20K gal IG, pebble tec, 2 HP Hayward Northstar pump, Hayward C5025 525 sqft cartridge filter, Polaris Caretaker 99 infloor pool cleaner, A&A Dek-Clor
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: New to forum and BBB
    Welcome
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Enjoy the clear water!
    Sent via Tapatalk...
    30,403
    Welcome to the forum.
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum. We're glad you're here
    You're done SLAMing when:
