Thread: Spa drains into pool when pump turns off!
    Jul 2010
    Richardson, TX (Dallas suburb)
    52
    My spa (slightly elevated from pool, overflow into pool) is draining into the pool when the pump stops running. I was told something about a valve...can anyone explain how this works (or in my case, doesn't work)?
    Brian, Richardson TX. 25K Plaster Pool, 1.5 HP Pump, Polaris 280 w/ 3/4 HP Booster Pump, 325 sq ft Cart Filter. This is my 3rd pool to convert to BBB method.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: Spa drains into pool when pump turns off!
    You have a bad check valve or one of the diverter valves isn't closing completely. Try using the search box. You'll get a bazillion hits, so try to narrow the search to thread topics or first post only.
    Hemess's Avatar
    Norman, OK
    95
    Quote Originally Posted by Richard320
    Ditto...happening to me too...
    28,000 IG, gunite, IntelliChlor IC40 SWG with SPA,
    Intellichlor/VS Pentair
    Norman, OK
