Thread: Pump Speed
    Pump Speed
    Hi to all;
    I have a Hayward 1HP super pump installed in my system. The pump really seems to big for my needs. Is there any way to rewire the pump to run at a lower speed perhaps with a switch.
    Many thanks,
    Gary R
    18 X 32 Oval Inground Gunite Pool 20,000 Gallons Epoxy Painted in 2012
    Tagelus Sand Filter TA 60 D/TA 60-Hayward Super Pumps 1 H.P.
    Ray-Pac Heater 266,000 BTU, KLeen Machine Pool Cleaner
    Solar Cover-Rocky's Pool Cover Reel-Intermatic T104R Timer
    TF-100 Test Kit-PoolSkim Skimmer
    38,251
    Re: Pump Speed
    A 1HP Super pump is really not a big pump (it is not a Super II right, which is larger). Anyway, what makes you think it is to big? You could likely go smaller if you have not high flow rate needs.
    But, you can not change the speed of the motor if it is not a 2-speed motor. Cheapest alternative would be to keep the pump and replace the motor with a 2-speed version and then you could use a switch to select high / low speed.
    BTW: Please keep your signature under 5 lines long ... thanks
    Re: Pump Speed
    Hi Jason;
    Many thanks for the reply!!
    The pump seems large because it pushes us around the at a fairly good clip when I have the Pool Skim attached which is most of the time. Filter is at 20 psi unless I use the eyeball which bring it down to about 15 psi. Maybe it's just a resistance issue??
    Thank you,
    Gary R
    38,251
    Re: Pump Speed
    Good circulation is good to have. Some pumps on low speed may not do a good job on skimming the surface.
    How long are you running the pump? Might be able to save $ on electricty by running less ... if that is the concern. But if the concern is just the movement of the water while swimming ... then just turn the pump off
