Results 1 to 10 of 10
Thread: Adding SOLVED to end of post. SOLVED!
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Hello,
    On some other message boards they recommend adding SOLVED at the end of of the title of the original post when the problem is fixed or resolved. It makes finding answers easier to find and kinda shows the end message. Just a thought.
    30,415
    Re: Adding SOLVED to end of post.
    I think thats a very good idea.
    It is disappointing when OP never responds to possible fixes but it is very nice when they do........... providing the solution so all can see and learn.
    Adding "SOLVED" to that last post would seem to me to be only beneficial with no down side. Anyone else?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Seems good to me, and as bobo suggested, editing the title of the thread would be even better. Most won't do it though, I'm sure.
    Christian's Avatar
    Jul 2012
    Sacramento, California
    304
    Re: Adding SOLVED to end of post. SOLVED!
    I'm with MITS, it's a great idea but I'm not sure it will stick.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Does editing a post put the thread back at the top? If not I'd be willing to go back to my posts and put SOLVED on them, but I don't think they need to be brought forward again. And what happens if it's marked solved and then additional posts are put on, does it need to be re-edited?
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by msgtdan
    Editing the FIRST post in the thread and changing it's title changes the title for the thread. I don't think it bumps the thread as being unread; I think only new posts do that.
    If the first post title, which is the thread title, is changed, Individual posts will still retain their titles which, if not changed, are inherited (I'm not sure if it inherits the thread title or the previous post's title).
    If additional posts are added on, the thread title does not change so does not need to be re-edited.
    Apr 2011
    Murrieta, CA
    2,360
    Just tried it to my an old post of mine. (Changed the title of the first post added SOLVED, it did not move it to unread or new post listing.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: Adding SOLVED to end of post. SOLVED! SOLVED Again!
    Okay, I'll go back and edit subjects on some of mine.
    Dan D
    Aug 2011
    South West Idaho
    20
    What about taking this "SOLVED!" suggestion and making it more official by placing it in the appropriate thread in the Pool Rules area?
    Spa - Tiger River Spas Sumatran, 2003(I think) 310 gallons, Filter - Cartridge, Type - Acrylic, Pump Motor - Silent Flo 5000 circulation pump & a Wavemaster jet pump, Other - Has a Ozonator. Owners Manual
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I think it's a great idea and I have begun promoting it.
    Essential Links:
