Thread: Caretaker 99
    Caretaker 99
    Caretaker 99 in ground system: I am new to this system. The pop up heads: is there a specific way they the jet should point from one end of the pool to the other.
    22,553
    Re: Caretaker 99
    Welcome to TFP.
    Those heads should rotate themselves a bit every time they pop up, so there's no aiming them in a certain direction. If they're not rotating, they need to be removed, cleaned and reapired/replaced if needed.
    My 15,000th post
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Caretaker 99
    My 15,000th post
    :P
    Bama's got it right; they should rotate each time they pop up. The heads aren't synchronized with each other in any way either; i.e. all pointing the same way at once.
    Mar 2011
    Scottsdale, AZ
    406
    Re: Caretaker 99
    Actually they rotate every time they go down, not up.
    Per the original install instructions they all should start pointing the same direction. I personally start them all pointing at the main drain, helps keep debris from building up around it. If you think about it, it makes sense that they sweep together clockwise. They rarely stay that way.
    Dont forget there is a screen above the water valve that has to be cleaned.
    malcolmb5325's Avatar
    Sep 2009
    Sydney, Australia
    166
    Re: Caretaker 99
    Yes it is always best to start the floor heads all pointing towards the drain. This stops the heads "fighting" against each other when squirting out the water jets.
    16,000lts Fibreglass, Magna Mineral Pool Water
    Jandy CV340 Cartridge filter, Zodiac TRi SWC, Z4 iAqualink, Jandy Laminar Jets, Solar Heating, Spa Jets with Jandy 1.5hp Epump operating everything.
    Oct 2009
    3,899
    Re: Caretaker 99
    Ideal, yes; realistic in the long term, no. As soon as people get in and start stepping on them like whack-a-mole, they'll be pointing every which way!
