Thread: Possible hard freeze
    I am in North Alabama and decided not to close my pool this year. So far so good. We have had freezing temps but nothing that has not recovered the following day. Next week we are forecasted to be below or at freezing for about 36 hours ranging from 20-32 degrees. I have the aqua plus and is set up to run below 35 but will that be good enough to keep anything from freezing? I have it set to run at 1750 rpm, do I need to raise the rpms to ensure my pipes don't freeze? Any advice would be appreciated!
    18x36 Grecian Vinyl; 8' Roman steps w/t 2 spa jets; cozy cove w/t 6 spa jets; 2 MD, 1 Skimmer, 3 returns; Hayward Ecostar, 30" Ranger sand filter; Hayward color logic 4.0 LED light; Hayward aqua logic; 2" PVC pipe 4 Jandy Valves
    22,550
    Re: Possible hard freeze
    As long as it doesn't get a lot colder than 20F for an extended period you'll be fine.
    I suggest you have a backup plan in case the power goes out. Like maybe a generator, or be ready to drain and/or put antifreeze in the lines if it does happen.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Thanks Bama. When you say drain would I need to do anything other than pull the plugs on the pump and filter? What would be the best way to get antifreeze in there at that point with no power? Hopefully it doesn't come to that. As of now no snow or sleet is forecasted so power shouldn't go out.
    22,550
    By draining, you need to drain anything that has water in it above the frost line. Pump, filter and any piping you can drain. I'd pour the antifreeze into any piping leading to or from the pool. A couple of gallons poured in the plumbing should be enough. Hopefully the power won't go out and you won't have to worry about it at all.
    Looks like temps will get above freezing everyday now thankfully. Appreciate the advice Bama.
