Results 1 to 7 of 7
Thread: Where to buy new inground liner.
    pooly1's Avatar
    Mar 2012
    Michigan
    107
    Can anyone recommend where to buy a new in-ground liner? I have a 16x32 in-ground. Looking to order the new liner in just over a month. Budget is $1000.00. Thanks!
    Jordan
    16 x 32 Inground Vinyl 21000, 2 returns, 1 skimmer, 1 main drain. Raypak Heater, Crystal Flo Sand Filter
    Oct 2012
    209
    Re: Where to buy new inground liner.
    Is it shallow or does it have a deep end?
    24' round above ground, 13500 gallons, vinyl liner, 18" Sand Filter
    pooly1's Avatar
    Mar 2012
    Michigan
    107
    It has a deep end and a shallow end with a gradually decline, no shallow area on the side in the deep end either.
    Oct 2012
    209
    I am afraid that given the size of your pool you will be hard pressed to find a liner for under 1000. For the dimensions you gave, I would say a decent liner will run you anywhere from1500 to 2000 bucks. That does not include installation, gaskets, etc... As far as quality is concerned I think those manufactured by GLI are very good.
    pooly1's Avatar
    Mar 2012
    Michigan
    107
    http://www.poolsinc.com/16-x-32-rectang ... liner.html So is this one or this site an okay liner?
    Oct 2012
    209
    I have never heard of this company before. Also it does not state for what depth of pool this liner is for. That being said, there are a couple of things to keep in mind when ordering a liner (as a homeowner).
    1) Every pool is unique. To get the best fit out of a liner there are several measurements that need to be taken using the correct form for your type of pool. If you buy a generic fitting liner you may regret it. For example: We replaced a liner in a 16 by 32 pool this summer. It had a 3.5 foot shallow end, and a 8.5 foot deep end (probably very similar to yours). The owners said the old liner always had wrinkles in it...also it tended to pop out of the liner track at 2 diagonal corners. In fact, it was in these corners that the liner eventually ripped. We found out why through our measurements. The pool itself was built half a foot out of square! The company that made the liner was able to compensate for this by using the measurements we provided.
    2) You get what you pay for in a liner. Check with the BBB on this company you want to buy the liner from. Make sure they have been around for a while, and will be around for a while. Make sure they stand behind their warranty. Make sure the warranty will actually cover what it says it will cover and that it will be enforceable if you do have a problem.
    Also pool liner companies will not take back a liner whose box has been opened. It is your responsibility to make sure it will fit.....so double check those measurements!
    pooly1's Avatar
    Mar 2012
    Michigan
    107
    Hey thanks for all the good information, I will look around for sites to buy a GLI liner.
