Results 1 to 12 of 12
Thread: Pump Problem - Hums & then pops breaker
    When I attempt to start the pump:
    - Motor hums for a few seconds
    - Circuit breaker pops
    I tried opened the downstream bleed-air valve and it was enough to allow the pump to start turning and then it appears to have run fine. Water flow (based on eyeballing the spill over into the pool from the spa) appeared to be normal & the pressure at the filter also appeared normal. But, if it's left alone ... it won't get going by itself.
    I also opened the strainer on both this pump and the waterfall pump. I can turn the waterfall impeller by hand but I am unable to turn the pool pump's impeller by hand. If I put a wrench on the back of the pump motor, I can turn it fairly easily. So, the impeller isn't jammed but it does seem to turn hard.
    Recently, I had a control valve actuator go bad and the system ended up draining the spa overnight and running the pump dry - no idea for how long. If it matters, it wasn't hot out (in fact, it was the Freeze Protection mode that kicked it on at night).
    Does it sound like I just have a bad start capacitor? Or, is the pump binding for some reason?
    M2
    Re: Pump Problem - Hums & then pops breaker
    Welcome to TFP!
    If it ran dry for a while it would have over heated the pump body, which probably then distorted and is now partially jamming the impeller. Chances are you now need a new wet end chassis. The other possibility, rather less likely, is that the motor bearings are starting to go bad, but that would have developed slowly over time, which it doesn't sound like your problem did.
    Thanks for the reply. I see that I could have been clearer in my original post...this problem was occurring before the spa ran dry but only occasionally. Now, it's every time. Is there a way to test/inspect and determine if the pump body is warped? I haven't noticed any of the typical noises associated with a bearing going out (e.g. squealing)
    22,548
    You should be able to turn the impeller by hand fairly easily. If you can't then something is binding. It could be a bearing and it not make a squealing noise. It could be something caught between the impeller and the casing. Or, as Jason mentioned it could be something warped.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Remember that the pump is really 2 different things. The electric motor and the wet end (actual pump).
    It could be an old leaking seal, that makes bearings go bad. If you overheat the motor enough the insulation on the winding starts breaking down, then the motor will be no good.
    As Jason said, if the actual pump housing heated and deformed then you might be able to salvage things, but it won't be all that easy.
    You'll may have to pull the motor to check.
    What kind of pump?
    How old is the motor?
    1.5HP Whisperflo
    I'll go ahead & pull the motor off and see if I can find out more.
    Problem-solved.
    Dog hair
    The strainer let just enough through to wedge the impeller. Now... for the "other" problem: keeping the dang dog out of the pool.
    Apr 2011
    Murrieta, CA
    2,360
    GREAT!
    22,548
    Glad it was nothing more serious.
    Aug 2007
    near the swamp
    806
    that had to be A LOT of hair to do that lol
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Using skimmer socks should keep the hair out of the pump, at least!
    Quote Originally Posted by Melt In The Sun
    Excellent. Didn't know about those. Thanks for the tip.
