Thread: ic 40 finally died..need help with replacement
    Hello everyone! At the end of this last season, our ic40 fianlly gave up the ghost after almost 5 years The first two years I had it running at almost 100 % because I didnt know it would eventally need to be replaced...DUH!
    Anyway, I am just making sure that i need to replace the whole unit, not just a cell part inside. I know it is wishful thinking but I justhave to ask before I spend $500 on something.
    THanks for the help.
    Jeffrey
    30,000 gallon vinyl lined salt water pool in KCMO
    Whisperflo pump wf-28 2HP
    Tagelus sand filter 40/400
    Intellichlor ic40
    Re: ic 40 finally died..need help with replacement
    Yes, somewhere around $500. You do need to replace the entire cell assembly, but you do not need to replace the power supply.
