Results 1 to 8 of 8
Thread: Gas connections
    Gas connections
    A question for the gas experts:
    I am currently overseas, and for the last two years have been using a setup that connects my grill to my main home propane tank. Basically there is a regulator connected to the tank, and then I have a 30' length of rubber hose (the kind used for air-powered tools, such as in an auto repair shop). The hose connects the tank/regulator directly to the grill, and it works perfectly.
    My question is this: is there any problem with this setup? Can I use the same setup for my home in Florida?
    1) 9250 Gallons (35k Litres)
    2) Sandpiper 650 sand filter
    3) IG pool - Waterline tiles,concrete shell with Washington white pebble and diamond brite finish.
    4) Flow rate of filter is 4000 Gallons/Hr (15k L/H). )
    5) Build in 1993, MELB AUS
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Gas connections
    There are hoses and fittings designed for portable gas connections. But please be aware that there is a difference between appliances that use propane and NG. You can't just hookup any gas grill to home's NG supply.
    chiefwej
    Aug 2010
    New Caney, TX 77357
    184
    Re: Gas connections
    Just to be clear, when you say "the same setup" you mean continuing to use a propane tank with a 30 ft hose correct?
    20K gal, inground with attached spa, pebblefina plaster (bella blue), flagstone coping, moss rock waterfall, Sundek - Indian wheat, (2) Jandy PHPM2.0 (filter pump and waterfall), Jandy DEV60 DE filter, Polaris 280 pool cleaner, Polaris Halcyon PB4-60Q booster pump, Polaris 1.5 HP Air Blower, (2) Jandy WaterColors LED lights, Jandy LXI400P Heater, Jandy AquaPure PLC1400 SWG, Jandy AquaLink RS PureLink Controller and PDA.
    Re: Gas connections
    Exactly
    Aug 2010
    New Caney, TX 77357
    184
    Re: Gas connections
    On the surface I don't know why it would be a problem but I really have no idea if that setup falls under any state regulations. Maybe someone in Florida knows or can point you in the right direction to confirm.
    38,371
    Re: Gas connections
    Just on the surface, I have my doubts that it meets code. Having a 30' rubber hose laying on the ground that could easily be damaged and result in an explosion
    But, then what is the legal length of a hose to do this? As I know many people that hook their grills up to home NG supply with rubber hoses. I am certain there are details in the FL code that you would have to investigate to meet code ... but there is still the question of the amount of risk you are accepting.
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Re: Gas connections
    Do it properly. Run a copper line from the tank or T off of the line that is already there. This is the proper way to do it for propane. Rubber lines/hose are a no no.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Feb 2012
    Greenville Indiana
    35
    Re: Gas connections
    As a hvac service tech, in KY and IN all gas connectors must either be hard pipe or an AGA approved gas appliance connector. Thehard pipe is either blblack iron or copper, an AGA approved connector will have some means of protecting the connector hose. Examples of good connectors are corrugated tubing with proprietary ends and requires a certification by the mfgr to install, commercial appliance connectors less than 4ft with a lanyard connected to a quick release, or a special hose material with several layers of internal armor to protect it from being cut. The least expensive solution on lp or propane will be the buried copper line. I tell my customers to have the lp supplier to run the necessary lines and set the pressures properly, the lp company has access to tubing engineered for this purpose and is usually less expensive. I have seen instances of homeowners doing their own gas work and their insurance refuse to pay after a fire. Air hose tubing is not intended for gas and would be dangerous to use. Gas attacks some types of plastics and rubbers, natural gas should never be used with copper. Natural gas is corrosive to copper and will eventually eat through. Please have a trained and bonded servicer do your gas work!!
    27' x 54" Cameo by Backyard Leisure (Wilbar) 17,200 gallon
    Hayward S180T filter with a 1.5hp pump
    Zodiac Barracuda Ranger vacuum
    GLI fencing around top rail
    All piping hard piped (that is what I do far a living!)
    six 2'x20' solar panels
