Results 1 to 8 of 8
Thread: water test and balance
    Jan 2013
    Melbourne Australia
    12
    Hi I got my TF-100 today and tested the water
    Results are
    FC 19
    CC 1
    TC 20
    TA 70
    CH 140
    CYA 95 I THINK OR MAYBE 60 NOT SURE IF THIS IS READ RIGHT??
    ph 6.7
    OK so the water is still a little cloudy can someone tell me what to do please thanks
    Davey Sand filter
    IG Vinyl
    Pump Viron P280
    Approx 50,000 litres of water
    22,553
    Re: water test and balance
    It makes a big difference whether the CYA is 60 or 90, but in either case you're not at shock level with an FC of 19. Run the CYA test again and see if you can narrow it down a bit. I pour the mixture back and forth a few times between the view tube and vial to get a better reading.
    Once you've narrowed the CYA down you will either need to drain some water to get the CYA down and then begin shock or you need to begin the shock process on the pool.
    30,431
    I would do like bama suggests and define your CYA a little better. It doesn't have to be perfect but you should be able to get within 10-15ppm each time you do the test. Again, as bama suggests, you do not need a new sample each time....simply use the same sample over and over until your result is consistent.
    While you are doing that, let your FC drift down to about 10ppm or less (it should take a couple of days) and then retake the pH test.
    Your pH results will not be very precise when FC is above 10ppm like it is now.
    If your pH is still testing at 6.7 (and I think it will), then you need to raise it up to around 7.4 or so to get within normal parameters.
    Once your pH is up to normal, you can plan on starting the shock process to get your pool in perfect shape.
    Jan 2013
    Melbourne Australia
    12
    hi I retested today the new results are
    FC 10
    CC 0.5
    TC 10.05
    TA 100
    CH 130
    CYA 80
    PH 6.8
    do I need to add more chlorine? and what products do I need to add to make the water perfect, it is pretty clear now. I am having friends over tomorrow night so I want to make it good to swim in.
    thanks
    Davey Sand filter
    IG Vinyl
    Pump Viron P280
    22,553
    I'd run the pump from now on till the party. I'd also bring the FC up to 30 ppm with liquid or cal-hypo and keep it there until about an hour or two prior to the party. You should also aerate the water to bring the pH up a bit. If you can adjust an eyeball up to where it breaks the surface, that should do it.
    What do you use to chlorinate the water? (Liquid, Pucks, etc.)
    Jan 2013
    Melbourne Australia
    12
    I use both liquid and the disks. how much liquid do I need to add to get it up? and how do I aerate the water thanks
    Davey Sand filter
    IG Vinyl
    Pump Viron P280
    38,426
    A waterfall or spa spillover will aerate or do as was previously suggested and change the return jet.
    Learn to use poolcalculator.com to determine the amount off chemicals you need. You must stop using the the pucks since your CYA is already high and they will just make the problem worse.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Jan 2013
    Melbourne Australia
    12
    Ok I will do that, just to let you know I have calcium build up on the walls, is there a easier way of getting it off without scrubbing? and could this be causing the issues with any of my levels?
    I am wondering if I am able to put a fountain on my pool as there is only one thing that pushes out the water.
    Davey Sand filter
    IG Vinyl
    Pump Viron P280
