Results 1 to 11 of 11
Thread: Auto Cover info - CoverStar details?
    Jan 2013
    Austin, TX
    27
    I'm having trouble getting any real details on automatic covers - aside form the CoverPools site,
    http://www.coverpools.com/pool-cover-sy ... O7Zo2-x99U
    there really isn't a lot of good info on CoverStar or any other companies? In fact, what are the other companies?
    My PB uses CoverStar and it seems that many on this site do as well, but there has to be some other options out there. I may be a sucker for marketing or maybe I put too much weight into a company's website/content, but I almost get the impression from CoverStar that it's set up to allow it's "reps" to change options, warranty details and pricing to better maximize profits.
    for example:
    1. Apparently there's a CS3000 and Eclipse model of cover (any others?) - I can't find out any info on these through the site
    2. The warranty page only mentions the fabric - am I crazy or are there other parts of the cover that seem to be pretty important? http://www.coverstar.com/customer-support-2/warranty
    3. The site says my closest dealer is in Indiana (I'm in TX) - can that be right?
    4. No details on the motor, ropes, or anything! Watts, HP, build materials would all be good info to have, right?
    Thanks! This may seem like petty stuff, but the auto cover is not cheap and I don't think it's crazy to want a little detail on the produce.
    My current plans...
    11 x 32 IGP w/ spa ~10000 gal
    Gunite w/ NPT Quartscapes Luederstone coping
    Badu Stream II Pkg A Swim Jets
    Pentair VS pumps with Intellitouch/ScreenLogic controls
    jjslinger's Avatar
    Sep 2011
    Santa Rosa, CA
    97
    Re: Auto Cover info - CoverStar details?
    Another company is Aquamatic (http://www.aquamatic.com). There's quite a bit of information on the website. I've had one for nearly two years with no problems. It takes a little practice to get the "skew" adjustment just right (how much one side is off from the other when in the "open" position), but I'm getting the hang of it.
    Don
    16K gal IG 16'x28' pebble since 2011; Pentair Easytouch; Sta-Rite Intellipro VS pump; Sta-Rite 400 sq. ft. cartridge (System 3); 6 Heliocol Solar Panels; Aquamatic Cover; Legend pressure-side cleaner with Hayward booster pump; TF100 Test Kit.
    Nov 2011
    Moberly,MO
    1,010
    W e are a builder in Missouri, we have used both Aquamatic and Coverstars. We originally sold the Aquamatic line, but we switched to Coverstars since the webbing at the edge of the cover is heat welded to the cover material instead of stitched together. This is a trouble area of Aqumatics, the stitching deteriorates in the sun and then the cover pulls loose from the webbing and track. As far as warranty it is like any other warranty, a lot of it will depend on the installer and how good they do at getting the system installed correctly. What kind of chlorination are you going to do? If you are going with swg I would use a coverstar eclipse system since it is a stainless steel unit instead of aluminum. Also look at www.coverstarcentral.com this will have more of the information you are wanting.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Jan 2013
    Austin, TX
    27
    Thanks for the insight on the CoverStar product and the link - that's a much better website.
    I'm hearing more good things about CS so I'll probably go that way - I was really just curious why it was hard to get an real detail on their product.
    My current plans...
    Nov 2011
    Moberly,MO
    1,010
    I will mention it to our dealer contact for them and maybe they can improve their website. Personally as an installer the coverstar is a much nicer finished look. I like to build what is commonly known as a pool-in-poolwith concrete lids for the mechanism trough. This just adds a very finished look.
    jjslinger's Avatar
    Sep 2011
    Santa Rosa, CA
    97
    Quote Originally Posted by swimcmp
    I have concrete lids on mine, you can see my pool in the "open" position here http://www.troublefreepool.com/jjsli...er-t39868.html. The lids do look nice, but they are heavy, and that discourages me from doing as much maintenance as I should, I hate lifting those things.
    Don
    Jan 2013
    Austin, TX
    27
    Since I have a knowledgeable audience here, I have another autocover question. My pool and spa are basically 1 rectangle with a "dam wall" that the cover would slide over - should I have the cover roll up on the spa side or pool side? in other words, If I'm sitting in the spa with a margarita, is there any way I can tell there's a large cover rolled up behind my head or does it disappear under the coping? (doing brackets, no "lid")
    Thanks!
    My current plans...
    Nov 2011
    Moberly,MO
    1,010
    dperque you will have some sort of lid over the cover mechanism. Without seeing the pool/spa setup it is difficult to tell which way it should roll up. What I would recommend is to roll the cover away from the house. If the pool runs lengthwise with your house try to roll the cover so prevailing winds aren't blowing under the cover when it is closed.
    Jan 2013
    Austin, TX
    27
    PB came over today - we're going to put spa-side - and yes, it does run lengthwise, but the spa is a little tucked away behind part of the house and offers some better options for the housing/elec access. It will be under matching limestone coping so should look fine. Getting excited - just hoping my PB can work on the price a bit.
    My current plans...
    Try googling automatic pool covers Texas. It should bring up a dealer close to where you are.
    20,000 gal. IG pool/ 400 gal. spa combo, unpainted plaster; Hayward Pro Series sand filter; Whisperflow 1.5 hp pump; Pentair Minimax pool & spa heater; Save-T Cover II Automated pool cover; Maytronic Dolphin; Dragonfly pool skimmer; Baquacil.
    Hi I was wondering if you have found the information you where looking for about pool covers? I would like to answer any questions u may have
    Quote Originally Posted by dperque View Post
    for example:
