Thread: SWG Power Consumption
    May 2011
    Los Angeles, CA
    228
    Hello all,
    Have been in lurk mode for some time... but here is a question:
    The specs of SWG show power consumption of like 240W to 360W for the SWG models for my pool. Does the SWG run all the time the pool pump is running or does it go on and off intermittently?
    Thanks!
    Suley, West Hills, CA
    IG 23000 Gallons with IG Spa Gunite plaster, Pentair Intelliflo VS 3HP, Pentair Clean & Clear Plus 420 Cartridge filter, Teledyne Laars One series 400,000 BTU Nat Gas Heater, Hayward Max Flo 1HP Single Speed Spa pump, Noisy Spa blower, Dolphin Deluxe 4 robotic vacuum.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Re: SWG Power Consumption
    The SWG cycles on and off. If you set it at 20% it will be on 20% of the time. I run mine in that range and almost never have to run it above 30 or 40%.
    chiefwej
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    It depends on the brand. For Compupool CPSC series, they come on and stay on with the motor. You can adjust the output 10-100%. Depending on the model it will determine the max wattage output. It also can be hooked up for 115V/230V, and is self cleaning.
    mas985's Avatar
    Pleasanton, CA
    11,737
    The units that stay on but still have an adjustment for chlorine output, will usually reduce the voltage to reduce the chlorine output and thus the power consumed is also reduced. So either way, it is a fraction of the maximum power usage.
    Mark
    May 2011
    Los Angeles, CA
    228
    Thanks! That helps a lot!
