Results 1 to 11 of 11
Thread: total gallonage question with drawings
    I have a older pool and found the drawings of the original install in 1985, and on the drawing it states that I have capacity of 14040 gallons, I don't buy it. I have attached the dimensions, can someone knowledgeable look at this and see if there correct .I hope you can read it.
    Thanks for any help.
    Roth
    13000 in ground Wet Edge Satin Tahitian Blue, Pentair VS pump, Hayward DE4820, Hayward Vac, Pentair SWG IC 40, Pentair Intellibrite 5G, Intellibrite Controller,
    TF-100 Test Kit, Seminole, West Central Florida
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Re: total gallonage question with drawings
    I came up with about 13K gallons, You can get as accurate as you like using this~ http://www.poolandspachemicals.co.uk/volcalc.htm
    Dave My Pool Build, ODK Build
    22’X42’ Gunite Freeform 23K Gal, 10’X12’ Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
    Wow I thought it was more than 14000 gallons.
    Anyone please.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by roth79
    Anyone please.
    A "long" time ago (June-July 2012) I was obsessing over this, then someone told me that within +/- 20% it didn't matter much so I just stopped trying to pin down the answer with math - started sticking numbers into PoolCalculator.com and when I found a number that seemed to give accurate results (add what it said, measure, they matched) then I decided that was my "number". I don't really care if it is accurate or not - it works at a practical level so that's what matters.
    My advice is to follow my lead. Pick a number - any number - that seems rational. Adjust chemistry using PoolCalculator, measure the results. If the adjustment came out higher than expected, water estimate is too high, lower it; if the adjustment came out lower than expected, water estimate is too low, raise it. Eventually you get close enough to not worry over it. I started out thinking I had 18,000 gallons, I now think I have 13,500... the water is fun to swim in no matter what the truth is. BTW +/- 20% on 13,500 gives a range of anything from 10,800 - 16,200.
    22,553
    I get about 12,000 gallons. It's common for pools to hold a lot less than the builders say they do.
    38,527
    My quick estimate was also around 12k ... as UWV said, pick number and then use your chemical adjustments to better dial it in for dosing purposes.
    Thanks UWV, Bama (roll tide? if so congrats on a blowout) and JB, Thanks a lot....
    Roth
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Quote Originally Posted by pragmatic
    I guess you didn't like my answer?
    No bro Im sorry I did just missed the thanks so again THANKS.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,089
    If you really want the exact amount I suggest that you empty your pool before you fill it take a reading on your water meter before and after.
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
