Results 1 to 9 of 9
Thread: how long do you run your pump in arizona winter
    Apr 2012
    chandler az
    65
    new to pool, service guy has pool running 4 hours nightly 7 days a week. water temp is around 40 degrees. what do you guys do here. 20,000 gallon inground pool.
    Re: how long do you run your pump in arizona winter
    With the water that cold, one hour a day plus any time it is below freezing should be plenty.
    Nov 2011
    Magnolia Texas
    80
    I live in Houston. with the recent "cold" weather our pool water temperature is in the low 50's. I've cut the pump back to two hours and left the cleaner at an hour and a half per day. I also turned down our saltwater chlorinator to zero as I'm told it no longer functions with the water reaches around 55 degrees.
    28,000 gallon salt water pool
    DE Filter
    Inground plaster construction
    1-1/4 hp pump with 1hp booster pump
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    You sure your water is 40 degrees, in Chandler
    In Tucson, mine runs 4 hours a night, which is just enough to keep it clean-ish.
    38,271
    Wow I might be running mine more than needed. I think I hand it set for three 3 hour periods on low speed throughout the day.
    Thermometer reads 45 if it can be believed.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Apr 2012
    chandler az
    65
    mine themo reads 40, was 46 when we got here last week, Thanks for the responses> will report what i find
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Water temp 45 and I'm running the pump 3 hrs per day.
    chiefwej
    I'm in chandler also with a 42,000 gallon pool and was told to run it according to the high temperature i.e. if the high is 70 run it 7 hours, high 50 run it 5 hours etc. maybe I'm running it too much!
    As a general rule nearly everyone is running their pumps too much Recent research has shown that in most situations pump run times don't even need to be half as long as they typically are right now to get the same effect, at a substantial savings in electricity.
