Results 1 to 7 of 7
Thread: Pool Safety Cover
    Pool Safety Cover
    Hi there, I'm hoping somebody could help me out. We had a pool installed in the fall of 2012 and haven't yet had a chance to use it. Unfortunately my faith in our pool installer has demished which is why I'm turning to you for help.
    We had them install a safety cover and it doesn't seem to be adequate however, as a new pool owner, I may be wrong. We live in an area where we can receive significant snowfall at times. At our first snowfall, we may have received 2-3" of now. With this snowfall, our pool cover is about 3' below the deck level (pool not all the way full with water at this time due to local building codes). My concern is that with such a small amount of snow and the cover sinking at least 3', this doesn't seem to be overly safe. With two very small children, I need to know if this is in fact safe or if the cover requires a reinstall.
    If anybody could offer advice or provide clarification, it would be most appreciated.
    Thanks for your time.
    4knights's Avatar
    NE Kansas
    419
    Re: Pool Safety Cover
    I think it depends on the cover, my cover instructions say to lower the water level (no more than 2 feet) the springs on my cover are supposed to be at 60% compressed to be correct.
    I currently have 9 inches of snow on the cover and deck and the center does sag to water level. My cover instructions say the water supports the weight of the cover and snow.
    I would find out what brand cover you have and call the manufacturer for instructions, you may only need to tighten the springs or add water.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    We also had a safety cover installed as we have a little kid. We get a lot of snow here as well and have alot of water on top of cover, certainly enough to be a hazard. We were told by our pool store that the water will start to drain through cover as it ages and this is normal. We could have had a pond on pool for alot less money. Our water level was about 8" below deck when covered to allow for water to drain into the room left. We have about 8" of water/ice on the cover today so there hasn't been much seepage. Hoping to pump cover off today and try and tighten straps.
    12' x 24' IGP, 7700 gal, Jandy Aqualink PDA, Jandy LRZ 2500,000, Jandy CL 340 filter, 1hp Jandy Stealth pump, Jandy Aquapure SWG.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    The problem is you don't have enough water in the pool.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Quote Originally Posted by JohnT
    Exactly, sinking 3' means the water level is too low. Your local building codes have basically voided the warranty on your safety cover. The water level is supposed to be around 15" down from the top of the pool. Safety covers are strong but they are not magic. The weight of the winter snow load is supposed to be shared by the cover and the water/ice that is underneath the cover. Maybe you'll get lucky and make out with no damage but don't expect any damage to your cover to be covered by the manufacturer.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Thanks Kevin, that helps a lot. Luckily weather is cooperating this weekend and I'm able to fill the balance.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    No problem The exact level is determined by the make and manufacturer. Solid covers are meant to be kept higher than mesh style. Regardless around 15" should be good. If you have any papers on your cover it probably says the proper level in there.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
