Thread: Spa come with house.
    Jan 2013
    Victoria, Australia.
    5
    Hi, my first post.
    I purchased a house and it has an existing spa.
    It appears that the pump and heater side of it is somewhat home made.
    The pump looks like a pool type pump but it does function rather well.
    The heater is an electric and separate gas system. It is plumbed in series on what I can describe as a by pass line.
    The gas system looks like a house hot water service (Bosch 16B).
    My issue is that the heating side works very poorly, the electric heater works but I suspect it is not effective on its own.
    The gas unit is electric start using it's own battery pack. I have replaced the batteries and it does spark when the pump is turned on, but the gas does not light. I wonder if the unit is not suitable for the function or if the unit is faulty.
    I apologise for my description if it is confusing, maybe pics can help.
    Any help would be great.
    Thanks.
    1750L spa, RP2100 127 Heater, GTC CLP 12005 pump. Enclosed in private deck, budget spa but on a beer budget it works well.
    Jan 2013
    Phoenix, AZ
    2
    Re: Spa come with house.
    Congrats on the new house! Pics would definitely help! Many types of heaters, as well as many types of spas. Is this inground or portable?
    Post some pics of the spa, as well as anything you can show of the spa equipment,heater, and gas/electric hookup. Gas heaters are very quick heating units, whereas electric heat is more efficient, but can take 10x as long. Generally if you have spark (or can hear it), there could be issues with gas supply to burners, valve (to open gas supply), circuitry, etc.
    Serious Showcase Pool "I'm a builder, what can I say...." 5 - Intelliflo VS Pumps, 2 - Intelliflo XF VS Pumps, 1 - SPECK 450GPM 5HP Pump, 2 - SPECK 400GPM 4HP Badu SwimJet System, 3 - 520 Pentair Cartridge Filter, 6 - Pentair Intellibrite 5G Color LED Lights, 3 - Pentair LED Laminars, 2 - Pentair 400K BTU Heaters, 1 - Pentair UltraTEMP Heat/Cool Pump, Pentair Commercial Salt System (IC-60 x 3), Pentair Intellitouch i9+3, i10x, Screenlogic2 w/ Mobiletouch Remote, iPad, iPod, & iPhone Remotes, 3 - Pentair SpaCommand Remotes, Pentair IntelliCHEM w/ Stenner Pump/Tank upgrade, Paramount PV3 Infloor Cleaning System (52 heads), 3 - Paramount Clear O3 Ozone, 2 - Bullfrog Spa JetPaks (for Gunite Spa), 14 - Waterway Spa Therapies, 3 - Paramount MDX3 Maindrain, 1 - 3' x 10' x 2" Acrylic View Panel @ Swimup bar, 1 - 16' Custom Interfab Slide w/ 25 Ton Natural & Artificial Rock Combo Cave.
    Landscape & Patio? Only have 980 character limit!....
    Jan 2013
    5
    Hi, thanks for the reply.
    It is an in ground, under cover (in an enclosed deck).
    I believe at some stage a proper unit was installed as there are control buttons fitted next to the spa.
    I have diagnosed the fault to be the ignition control unit of the gas water heater. Pretty simple, no voltage is being supplied to one of the solenoids on the diaphragm. I will have to track down a new module. When battery voltage is applied direct to the solenoids, the unit will fire up and continue to operate. I will use the electric heater unit until I can source a module.
    We are experiencing some very hot days here is Australia so the heater is not exactly required right now.
    Jan 2013
    5
    Just an update, I did away with the old heating unit (gas and electric) when the pump snuffed it recently.
    As I had to have the system open to replace the pump, we decided to purchase a real heater suitable for pool/spa use.
    We settled on a Raypak 2100. Good price and well and truly good enough for our little spa.
    Thanks again.
