Results 1 to 7 of 7
Thread: Is this thing hard to replace?
    Dallas, TX
    227
    Has a small leak on the bottom that squirts more when back washing. Doesn't leak too bad but i a m assuming it will only get worse. Just noticed today one of the nuts on one side is missing.
    new house: TBDK gal IG plaster pool, filter Titan CM DE filter 36 sq ft , 1.5 HP Pump; Polaris 380
    30,403
    Re: Is this thing hard to replace?
    I think if you will replace that nut, it may stop the leak. Certainly a quick and cheap fix if it works. Get stainless steel nut.... don't tighten extra hard, just snug. If it still leaks perhaps tighten a bit more.
    Dallas, TX
    227
    Are those a standard size? I just happen to be at Home Depot right now.
    Dallas, TX
    227
    Grabbed 3-4 different ones. We'll see what fits.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Is that on your backwash line? If so, it shouldn't have any water in it when you're not backwashing.
    Dallas, TX
    227
    Quote Originally Posted by Melt In The Sun
    Yes it is. That is true. It seems to be worse the last time I backwashed. It was more noticeably coming from there as the water flowed out at high pressure. I found a replacement nut so we'll see if that helps next time I backwash. Thanks to all.
    That's actually not true. I have a lot of pools that have standing water in the backwash line with no leaks on the backwash valve. If he has a P-trap where the pipe goes above the height of the sight glass he will have standing water in there.
