Results 1 to 10 of 10
Thread: Trying to figure out what kind of "jet" I need
    People,
    2 jets in my pool- the jets have been "chopped off" from a pool guy a while ago, exposing pvc threads. The thred ID is about 2 -1/4", best I could measure under water. Is this a standard size?
    I have been running my pool for a year without the jet heads/tips. Now, pool level is way down, and Im wanting to take advantage and finally screw on jet tips again, but need to buy them.
    Found this:
    http://www.spadepot.com/shop/Waterway-6 ... map=212-45
    Would this be a jet? Doesnt say what the thread size is, as far as I could see.
    Tips[img][img]javascript:void(0);[/img][/img] appreciated!
    16,000 gal in ground, marcite. FL.
    Re: Trying to figure out what kind of "jet" I need
    oops, cant get the photo uploaded.......will try again.....
    sorry, people, I just cant figure out how to upload the picture of my jet. It would have helped. If you have to have a picture, please advise, and I will maybe ask a friend to come over to help......
    ok, wow, found one here that looked EXACTLY like the one the guy chopped off, but man, its only 1-1/2". My ID is way over 2", probably 2-1/4 like I said. Why dosnt ebay offer my size........
    http://www.ebay.com/itm/1-1-2-Swimming- ... main_0&has
    Oct 2012
    209
    It is a directional or "eyeball" you are looking for. Is the faceplate still on the threaded part? Is it the ID or OD you are measuring? Is your pool older? Some older styles/sizes are impossible to come by. Try pool center....but you need to be sure of your measurement first. And there mist be a reaon your pool guy cut it off?
    24' round above ground, 13500 gallons, vinyl liner, 18" Sand Filter
    Oct 2012
    209
    Sorry didn't see you stated it was an ID measurement earlier. Plus, a jet will not fit those openings you are looking for a return fitting (directional or eyeball).
    Thanks, PJ. yes, it is a return fitting eyeball. Pool is about 25 yrs old. Gonna take a chance the width of the threads are 1-1/2". Theyre cheap, Ive learned. Hope it fits, otherwise, I will follow up with you in a week or so.....
    OK, got them , so anybody know if I need to put teflon tape on the threads before screwing them on?
    Thanks
    Oct 2012
    209
    No.you do not.
    Big thanks, PJ!!
