Thread: Pool Safety Cover installation - Did we do it right?
    Sep 2012
    Noblesville, IN
    83
    I ordered a safety cover for our new-to-us 24k gallon in-ground pool this fall. With my Dad's help (he's a professional pool boy) we drilled the holes for the anchors and installed it ourselves. When we had a company come close our pool (back in October) I specifically asked him if we should lower the pool water level for the winter (we're in central Indiana) and he said it wasn't necessary and he doesn't lower the water level when he closes pools. Since I was new to the pool closing routine I went with his advice. A few rain storms later the water level rose to cover the middle of the safety cover. I lowered the water level with a small pump I had and tightened the springs on the cover as it started to sag in the middle a bit. We've since gotten more rain and I'm sure the water level has come up a bit. Currently, we have snow and ice on the cover. It's very tight (50-75% spring compression) but the snow and ice have weighed the cover down again and the cover is, again, below the water line due to the weight of snow and ice on it. There isn't much I can do now that everything is frozen. I've read up on safety covers and see that we should have lowered the water level. We're due to thaw out later next week and I plan to lower it a foot then. (it may take all day with my pump, but we'll get there) My question: Is it common for ice and snow to weigh down safety covers? I know they're supposed to let water through but I would think snow would weigh them down. I can tighten the cover a little bit more before I get to the end of the strap length. How tight is too tight? Will the ice and snow damage my cover? (Ok, that's three questions....)
    32K in ground vinyl pool installed in the early 1990s
    1.5 HP Centurion pump installed in the September of 2012, replaced under warranty in August of 2013
    2.6 SF Hayward sand filter - age unknown but looks pretty new
    Jandy AE-TI heat pump - age unknown but looks new and works great
    Caretaker in-floor cleaning system - works, but not well....on my list of things to work on.
    Aqua-rite SWG - new in about 2006, T-15 cell replaced in summer of 2012
    4knights's Avatar
    NE Kansas
    419
    Re: Pool Safety Cover installation - Did we do it right?
    I think it depends on the cover, my cover instructions say to lower the water level (no more than 2 feet) the springs on my cover are supposed to be at 60% compressed to be correct.
    I currently have 9 inches of snow on the cover and deck and the center does sag to water level. My cover instructions say the water supports the weight of the cover and snow.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
