Thread: Pool Jet Replacement
    Hi All,
    A little background info: I am in the process of restoring a fiberglass pool built in 1989. The pool jets and wall mounts that I am assuming came originally on the pool were weathered, cracked, and needed replacement so I took them off. Now when I take my measurements, which seems to be a female, approx. 2 to 2.5" diameter for a wall mount, I canít find anything. I took some pictures with measurements and was hoping someone with more experience could steer me in the right direction.
    Thanks again for your help!
    - Matt
    [attachment=0:3ujgcv9e]Pool Jet Before.JPG[/attachment:3ujgcv9e]
    [attachment=1:3ujgcv9e]Pool Jet Dia.JPG[/attachment:3ujgcv9e]
    22,548
    Re: Pool Jet Replacement
    That looks like a standard wall fitting like this. I know it says 1.5" but the physical measurements are what you're looking for.
    24' x 52" Round AGP. 2hp/ľhp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Yeah, that does look like a normal 1.5" fitting with a 3/4" eyeball. The 1.5" refers to the pipe that it fits on the end of.
