Thread: Why is my Easytouch 4 causing pump to cycle off/on
    I posted this on another forum but as of yet not gotten much help...Hopefully you guys might have an answer.
    My pool and attached spa are controlled with an EasyTouch 4. The last week my pump has been cycling off and on every 15 minutes requiring me to reset. I had this problem in the past but was remedied by turning freeze protection off. I checked again and it shows freeze protection is off. The only thing different this year is I added an Intellichlor which I turned off last week. I was told this could be a firmware issue....If so how do I go about updating the firmware.
    Thank You
    Frank
    SCCS's Avatar
    Sep 2008
    Left coast
    79
    Re: Why is my Easytouch 4 causing pump to cycle off/on
    It will depend on what firmware you have now.
    If the pump is cycling due to freeze protection it could be: Freeze protection is on for the pool
    is on for the spa
    or there is another program set that has freeze protection enabled.
    16,500 gal Roman end with PebbleFina finish
    4 x 160 intelliflo pump
    Easytouch controls with an IC40 chlorinator
    Sta-rite cartridge filter
    A & A infloor cleaning system
    Pentair 5g LED pool light
