Thread: Does pH always read high when FC is high?
    May 2009
    Dallas, TX
    785
    pH 7.7
    FC 14
    CYA >40 (I treat it as if it were 50)
    TA 100
    CH 340
    Temp 44 degrees
    I am fighting mustard algae, so recently added FC to shock level to hit it hard while the water is cold. I made the mistake of not checking pH before adding the FC, but it last tested 7.8 which is right where I wanted it going into winter. So I'm a little confused as to current reading.
    My understanding of pH is that as the water cools and becomes colder, pH naturally rises? Also, my understanding of testing pH while FC is high is that pH may read *higher* than it actually is. I'm really trying to keep a close eye on CSI this winter. Should I be concerned with current pH reading?
    Edited to add temp reading
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    Aug 2010
    Dallas, TX
    4,052
    Re: Does pH always read high when FC is high?
    I ignore pH during the shock process.
    May 2009
    Dallas, TX
    785
    Quote Originally Posted by RobbieH
    Me too normally, but that's because I expect it to be higher than normal not lower...
    I'm about to raise the FC level again, so that will really skew the pH beyond reliability. You still think I should just ignore the pH reading?
    May 2009
    Dallas, TX
    785
    Um, forgot to mention that I added calcium chloride this morning to raise CH level. I assumed that it would be pH neutral, but maybe not?
    Jul 2011
    Arizona & California
    805
    Calcium chloride is virtually pH neutral.
