Results 1 to 7 of 7
Thread: Pump parts
    Pump parts
    I have a broken impeller on the pump which powers my pool cleaner. It is a Magnatek Century Centurion, Pool and Spa Duty. 3/4 HP, 240v Cat. B668. Any idea where I can find a replacement. Through Google I can find plenty of motors and parts, but no pump parts.
    Thanks in advance
    Don Muncy
    14,000g IG Gunnite 10 yrs old DE filter 2HP pump Dallas TX
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: Pump parts
    Pool supply stores usually carry impellers. Look up a local pool supply store via google or your phone book.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Re: Pump parts
    Quote Originally Posted by donmuncy
    That is the motor information. You need the pump make and model.
    http://www.zodiacpoolsystems.com/Produc ... Pumps.aspx
    http://www.pentairpool.com/pool-pro/pro ... ump-17.htm
    http://www.hayward-pool.com/prd/In-Grou ... 002__I.htm
    I think that you probably have the Pentair/Letro. Can you find any other information on the pump, or stamped into one of the parts? You should also get a seal and a new O-ring.
    http://www.pentairpool.com/pool-pro/par ... ump-16.htm
    Support the site
    Re: Pump parts
    Thanks for the responses. Yes, this info came from the motor. I have not been able to find anything on the pump itself. I will try to look closer.
    Don Muncy
    Christian's Avatar
    Jul 2012
    Sacramento, California
    304
    Re: Pump parts
    Definitely sounds like a booster pump. Can you post or email me pictures? I'd be happy to help figure out which one it is.
    Re: Pump parts
    Yes, it is a booster pump. And, yes on close inspection, it is marked Letro. I just didn't look close enough before I posted. I got an impeller this morning and just got it installed.
    Again, thanks for the help.
    Don Muncy
    Christian's Avatar
    Jul 2012
    304
    Re: Pump parts
    Glad to hear you got it all fixed up!
