Results 1 to 11 of 11
Thread: Jandy watercolors LED lights won't cycle through colors
    Hi everyone -
    I've searched and searched the internet but can't find any info. I have 2 Jandy watercolors LED lights that won't go through their color cycles automatically. I've turned them off, turned the power off, turned them off for 3 seconds, 4 seconds, 6 seconds, 7 seconds, 8 seconds...etc. I turn them off and on and they will go to the next color but the automatic color cycle isn't happening.
    Any ideas?
    Angie W.
    16,000 gallon gunite pool diamond brite finish, 2HP V.5. Jandy ePump
    Jandy 250 sq ft cartridge filter, AquaPure SWG
    Jandy Watercolors LED lights
    Angie W.
    __________________________________________________________
    Mike_W's Avatar
    Aug 2011
    Orange County, California
    142
    Re: Jandy watercolors LED lights won't cycle through colors
    Angie,
    If you are manually controlling the lights, you do need to work through the sequence of steady colors to get to the auto cycling colors. The sequence is:
    1 Alpine White
    2 Sky Blue
    3 Cobalt Blue
    4 Caribbean Blue
    5 Spring Green
    6 Emerald Green
    7 Emerald Rose
    8 Magenta
    9 Violet
    10 Slow Color Splash
    11 Fast Color Splash
    12 America the Beautiful
    13 Fat Tuesday
    14 Disco Tech
    To reset to the top - Alpine White - Turn the light OFF, wait four to six seconds, then turn ON.
    Then go through the sequence of turning the light OFF and then ON within three seconds. When you have reached the desired color or color cycle turn it off for more than 7 seconds and it should remain in that state next time time you turn it ON. Just don't turn it OFF for at least seven seconds each time you turn it ON or it will/might reset to Alpine White. Here's a link to the owner manual:
    http://www.zodiacpoolsystems.com/~/m.../H0305600.ashx
    HNY!,
    Mike
    ~17' x 34' IG pool with attached spa - 20500 gallons - Gunite with a "pebblesheen"-ish finish
    Jandy iAqualink with iPad and Jandy PDA remote - Pentair IntelliFlo VS 11018 Pump
    AquaRite SWCG - Pentair SMBW 4060 DE Filter - Really Old Raypak heater
    "Wall-E" an Arneson-Hayward Navigator - A couple of Jandy/Zodiac WaterColors LED Lights - Blue-White F-1000 Flow meter
    Cycling through them all is the one thing I didn't try! Thanks I will do that and post how it goes.
    Angie W.
    Oct 2011
    Frisco, TX
    47
    Why does it need to cycle each color to get to the one you want.
    Size 13,000 gal | Filtration Jandy DE 60 | Sanitation PLC1400 SWG, Rainbow 320 | Placement in-ground (IG) | Coping Tennessee Crab Orchard
    Finish pebble smooth Tahoe Blue | Pumps Intelliflo VS+SVRS 3.0HP main | Lighting Jandy LED Spa/Pool
    Location Frisco TX US
    Mike_W's Avatar
    Aug 2011
    142
    Brian,
    By using the power cycling control logic, a separate control interface is not needed. A separate control interface would mean two or four more wires going to the light, and you would always need a dedicated controller for the lights. While a bit awkward, the power cycling method is simple to implement even if you control your lights from a simple on off switch. Jandy/Zodiac and many other vendors use a version of this approach. Note that once you have got the light operating in the color/color cycle you want, the light will start in that color every time you turn it on, unless you power it on and off rapidly.
    Mike
    Ok so I cycled through all the colors and at the end it started going through all the colors VERY fast, like less than a second on each color. My 13 year old son informed me that if you cycle through (by turning it on and off) to the RED color and stop, it will automatically start cycling at a normal speed. Don't know why but it works! Thought I would post it here in case anybody else has a problem.
    Thanks everyone!
    Angie W.
    Mike_W's Avatar
    Aug 2011
    142
    Once again, a 13 year old solves a tech problem for his parents. Glad you got it working.
    Mike
    38,275
    You likely just scrolled through until you got to #10 which may happen to start as red and then go through the colors slowly. Sounds like you got to disco mode the first time.
    Try the other modes ... they may start with different colors so you have to count. I have a different system, but like the mode that is only blues and greens.
    For example, 12 is likely only going to be red white and blue.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Quote Originally Posted by Mike_W
    Mike
    What would we do without the youngsters? We'd live in a 1 color world!
    jblizzle - I had no idea you could get "modes" so thanks for that heads up! We'll play with it and see what combinations come up. The Jandy manual is woefully silent on all of this so I appreciate everyone's help.
    Happy New Year!
    Angie W.
    May 2013
    North East Ohio
    959
    Sorry to bring up a OLD thread, but I think it is the right place as I've tried this already. I have a similar light, and I can cycle all day long and it is stuck on 9 I think....no matter how fast I turn on / off my switch it stays "magenta".
    I have the Fusion Brand, whom I think Jandy acquired.
    Fusion Pool Products | LED Lighting for Underwater and Landscaping
    Anyways...any tips on how to UNSTICK a cycle ?
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    May 2013
    North East Ohio
    959
    I found a few more threads that said wait exactly 7 seconds, that did not work,
    Another said on for a minute, then off for 12 seconds, that did not work....
    I wish it would have stuck on a nice color the dang Magenta is not even visible at night barely....I tried calling Fusion, and they said they are out of business....this stinks.
    Any help on what I can try is appreciated.
