Results 1 to 8 of 8
Thread: Gutter/Deck drain question...
    Jan 2013
    Cleveland, OH
    70
    ]Given the below image, a few questions.
    The deck drain (outer edge) part is not draining; any idea where to look for blockage? I'm guessing it does not flow into the surge tank along with the gutter water/pool overflow.
    thanks
    20K gal, vinyl, 1 HP Challenger 2-spd pump, 300 lb sand filter, Raypak 266K BTU, 45M stenner pumpin' bleach
    30,426
    Re: Gutter/Deck drain question...
    Are you saying the deck drains into that outer slot? Got a pic from further back?
    Jan 2013
    Cleveland, OH
    70
    Yep, the deck drains water into the outside slot. Removing the cover plate in the pic reveals that outside channel, filled with water. I'd guess that the outside 'deck drain' channel drains into some other plumbing thatn the main pool gutter/overflow which empties into the surge tank. The 'deck drain' channel became clogged, I think, when deck was recently scrubbed/cleaned, pushing dirt and grime into it and clogging discharge path. I'd guess that this particular stainless steel gutter system has 3 distinct channels:
    1. Pool return
    2. Main gutter/pool overflow
    3. Deck drain
    30,426
    So the deck drains toward the pool? Indoor pool?
    Jan 2013
    Cleveland, OH
    70
    Yep, indoor pool. Judging from the manner in which wayward balls roll back towards pool, safe to say deck is sloped towards pool.
    Somewhere there has (I would imagine) to be something that allows water to drain from the outside channel...I just don't quite know yet where it is. Guess I could just ran a pressure washer directed into the drain slot all the way around the pool bu that would be quite the, uh, spectacle. Just curious if this type of gutter/system appeared familiar to anyone. Google-ing for and hints has so far proven fruitless.
    30,426
    How about one of the round, wooden "sticks" from home depot about 36" long? Inserted into the channel, it could be drug along with slight downward pressure until you find the junk blocking the drain hole or perhaps the drain hole itself.
    Jan 2013
    Cleveland, OH
    70
    I fear something like that will be the only option. A tedious task as there is a spot weld about every foot or so to impede smooth progress. Think I will try a metal yardstick...at least I won't have to bend down as I drag it along. Of course this assumes there IS a drain somewhere; I just can't imagine something like this wouldn't have a method for water to escape.
    There ought to be a drain in the bottom of the gutter every 5 to 12 feet, though it will work even if they are further apart than that.
