Results 1 to 8 of 8
Thread: Pentair Easy Touch 8 circuit
    When I select the Spa with heater choice the Spa drains. It has worked fine until now. I watched the actuator and it turned to the right. I can't tell from the operation guide how to check the programming. Not sure what changed to make it stop working properly. The heater comes on but empty Spa.
    Re: Pentair Easy Touch 8 circuit
    Welcome to TFP!
    Switching to spa mode turns one valve (supply) so that the pump draws water 100% from the spa and another valve (return) so that 100% of the water returns to the spa. If the spa is draining, some of the water returning to the spa must be going to the pool instead. Check that the return valve is moving and gets fully into the spa position. If the actuator is working correctly, check inside the valve to see if there is debris blocking full closing or a broken part inside the valve.
    Thank you, I switched the leads and the good valve stopped working so I know it's the actuator. Thanks again for the advice
    May 2011
    Orange County, CA
    696
    Did you check the switch on the actuator itself? It could be in the center/off position.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    Wow, it was. Do you know what on 1 and on 2 mean?
    Thanks to everyone, I should have started with the easiest solution first. The switch was off, how that happened I can't imagine. Saved me $130
    22,550
    The different on positions determine which way the actuator moves when power is applied to it.
    May 2011
    Orange County, CA
    696
    Quote Originally Posted by Tdattomo
    Yeah, that little switch is a bit confusing but handy. With it, you can adjust the flow in ways that the control panel cannot. By moving the switch from one side to the other, you can change the flow between two output ports. As the actuator is moving from one side to the other, you can switch it to the center "off" position, giving you flow to both output ports. This can be useful sometimes. In any event, glad to hear it was a simple fix!
