Results 1 to 11 of 11
Thread: Pop up head broke, plz help
    I just saw today that one of the pop up head broke, no idea why, is it common? what shall I do ? I am attaching some pics..
    11000 Gallons, Cartridge Filter, UG, Plaster, Shasta pool, filter model Hayward C4030, Pump Motor Emerson 1-1/2HP Full Rated EB2977T, Pump model Northstar SP4010NS
    Re: Pop up head broke, plz help
    You should be able to unscrew the whole piece and replace it. It might be a reverse thread. What brand is the cleaner system?
    Support the site
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    It looks like an A&A pop up. You need a special tool to remove what remains of the broken head. The tool goes into the two slots along the outside and a quarter turn counterclockwise releases the head. Check the lid on the distribution valve for a manufacturers name. If it is A&A contact them. I'm pretty sure they are based in Phoenix.
    chiefwej
    thanks your response, Now the water is really cold, can this repair wait for 2-3 months, will it damage anything if kept like this ?
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    It just means that the other heads in that cleaning zone won't get enough flow to work properly. It won't cause any problems.
    chiefwej
    Mar 2011
    Scottsdale, AZ
    406
    Fatboy,
    If you are a Shasta pool then it is A and A. How old is your pool? Are you the original owner?
    I assume you are in the Phoenix area.
    If you are the original owner then the parts are covered for life, if not it will cost you a bit.
    There is one company in town that that just does infloor repairs.
    Troy's Aqua-blue Pool Service. 602-992-0654
    They have all the parts and know how to make it work like new.
    Quote Originally Posted by Just-a-PB
    Fatboy,
    Yes, I have a Shasta pool.Pool was build in 2004, I am not the original owner, and I am in Phx area ! Any estimate on how much I should pay? can it be DIY ?
    RKRick's Avatar
    May 2012
    Queen Creek, AZ
    7
    Quote Originally Posted by fatboysam
    Fatboy,
    If it's an A&A (looks like style 3 if it is, can't see the top in your photos to be sure) then here is a link where you can purchase the head and the tool used to replace. The tool attaches on the end of a standard net/brush pool pole which allows replacement without having to get in the pool.
    http://www.webpoolsupply.com/pop-up-...ement-heads-1/
    21K Gallon IGP w/Spa, Blue Lagoon Pebble-Tech, Pentair Easytouch 8, Pentair VS 3050 Pump
    Pentair 1 HP Booster Pump, Blue Square Q-360 In-Floor Cleaning System, Pentair IC 60 SWCG
    Pentair Quad DE 100, Pentair Mastertemp 400, Pentair UltraTemp 140 H/C Pump (coming soon)
    Spectrum 360 LED Lighting, TF-100 Test Kit, Taylor Speed-Stir
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    You don't need to buy the tool...I made one out of a couple nails and a little piece of a tree stake. I can post a picture tomorrow.
    Oct 2009
    3,899
    Picture as promised. I just hammered some 6d nails into the wood, then cut the heads off and rounded the edges with a dremel.
    wow !! Thanks ,, I will try to make one
