Thread: Should I replace or fix my Jacuzzi
    I have a Jacuzzi hot tub that is 11 years old. The temperature sensor has gone bad and will cost a few hundred dollars to fix because the tub is built into a deck and the deck needs to be disassembled to fix it. I am not 100% certain it is the temp sensor, but reading online that looks like it is the most likely cause. It is displaying --- as an error code and is in watchdog mode.
    I need new pillows, and when it rains heavy sometimes the display will flash, requiring me to reset the breaker to get it to stop, so it could also be a board failure.
    The ozonator element is 4 years old.
    My question is….should I repair the spa, or at this point I am likely to have a heater or pump failure and should just replace the entire hot tub.
    The current spa is a J330, I have a quote for a J345 installed for 8300
    TIA
    19,000 gallon
    Cartridge
    IG
    1 HP Hayward pump
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,774
    Re: Should I replace or fix my Jacuzzi
    I suppose that depends on your own preference, but if it doesn't leak and is in otherwise good condition, I personally would fix it. I'm not sure what pump you have on that model, but my jacuzzi is 17 years old and only now have I had to replace the 2.5 hp variable pump motor at a cost including labor etc. of $800 -- so a tenth of the cost to replace the whole unit
    When I debated repair/replace, the repairman said mine was in excellent condition so it was really a matter of whether I wanted something new or was content with what I had.
    What error code are you getting?
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    I am getting "---" which indicates the watchdog feature has been activated. Most of what I read is that it is most likely a temperature sensor, but the whole board flashing thing when it rains makes me wonder if it is a bad board.
    19,000 gallon
    Cartridge
    IG
    1 HP Hayward pump
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,774
    I think if a board is bad, it's bad irrespective of weather. Sounds more like a loose connection or other exposure that could be remedied without replacing the board.
    Helpful Links:
