Results 1 to 15 of 15
Thread: Cheap Morton Salt Pellets - $3.79/40 lb bag at Sears
    May 2011
    Coral Springs, FL (near Ft. Lauderdale)
    93
    Sears has Morton System Saver II Salt Pellets on sale for $3.79/40 lb. bag. 99.8% pure, according to the bag.
    http://www.sears.com/shc/s/p_10153_12605_04203409000P
    I know they dissolve slower, but from what I read the difference is negligible.
    15x30 inground concrete pool w/spa and spillover, all under screen enclosure
    Hayward C1200 StarClear Plus Cartridge Filter and Hayward Navigator V-Flex
    Jandy AquaPure 1400, Laars LX400 propane heater w/120 gal above-ground tank
    Jandy VS FloPro 2.7 HP Pump VSFHP270JEP; FlowVis FV-C Flow Meter
    Jandy iAquaLink and OneTouch controller w/PDA remotes; JVA for draining pool
    Re: Cheap Morton Salt Pellets - $3.79/40 lb bag at Sears
    Thanks for the heads up - I'll be installing a SWCG soon. But is this the best option? Dissolve time is not a big deal, but Pool School says choose one that "doesn't have any rust inhibitor or other additives. The best choices include ... Morton® White Crystal® Water Softener Salt in blue bags".
    The linked on-sale salt is Morton's System Saver II. On Morton's website, it says this salt "help to prevent formation of iron and manganese sludge in your brine tank. Our specially patented formula helps keep these hardness minerals in solution". Sounds like this is the type of salt I should according to pool school. (unless I have iron staining problems?).
    Miami 13K gallon In ground
    Pool area screened in
    Pool built 1960's, last plaster/diamond brite ~2010
    Hayward Superpump 1.5 hp
    Hayward StarClearPlus C12002 Cartridge filter
    Morton® System Saver® II Pellets contain a resin cleaning additive. They don't appear to say exactly what that is. As a general rule, it is best to avoid adding things that are unknown or not needed, thus best to use solar salt, which doesn't have any additives. I don't believe that System Saver II is going to cause any serious problems, I'd just rather not experiment.
    Hi,
    Sorry not trying to bump an old thread but they had this on sale again and a coupon to make it cheaper. I'm new to pools and nee 350lb of salt according to the pool store. Its easy to cancel so I ordered 13 bags of this. After researching, I found people saying that this type of salt is alright, but not to use salt with any additives in it.
    Did anyone ever try this salt or should I not use it?
    I heard back from Morton today when I questioned them about the difference between the two products and/or their safe use in swimming pools. Here is their answer:
    “Morton Pool Salt is a plain salt product. Morton System Saver II pellets contain resin cleansing additives. Water softened by pellets is drinkable; however, if you have any type of specific health concerns, please see your doctor. Either product can be used in your pool.”
    http://poolforum.blogspot.com/2007/01/p ... ation.html
    Aaron
    26' Octagon, IG Pool, ~16gal, 5-5 1/2' deep, Liner, Sand Filter, Polaris Autoclear salt system, 3/4hp Pump, Pool Blaster Max Vacuum, TF-100 Test Kit.
    38,539
    I would cancel and just get the solar salt ... it is maybe a $1 more per bag
    Do you have an example of this? (link to it on lowes/home depot/etc) Thanks
    Aaron
    38,539
    Morton Solar Salt $4.78 around here at Lowes / HD
    http://www.lowes.com/pd_162421-62226-3983_0__
    Feb 2008
    Milford, CT
    337
    yeah same here, Lowes has the Diamond Crystal solar salt, HD carries Morton solar salt. Both are 4.7something per bag
    I felt the Morton stuff dissolved faster but the Diamond stuff was "cleaner" (I had only one bag of Morton but it had some white piece of garbage in it that didnt dissolve, maybe a pebble or something)
    22K IG vinyl, MaxFlow SP2302VSP pump, S244T filter, AutoPilot Digital w/SC-48 cell
    38,539
    I have gotten a pebble or 2 myself.
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    422
    Some things are worth saving on, but I would not use anything other than Pure 100% table grade salt
    ie, Morton's Pool Salt or Omega Salt - sold at pool supply stores. I prefer Omega it's like $7.00 a 40lb bag
    Why ruin an expensive SWG or damage plaster etc over a few dollars. There are other minerals and stuff in the other products.
    Just my 2 cents
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    38,539
    Solar salt is the same as "pool" salt that has not been put through a grinder. Why pay a extra $3 per bag to save a few minutes of dissolve time?
    And you certainly do not want to use iodized table salt.
    Feb 2008
    Milford, CT
    337
    Friend of mine is the same way....swears using anything other than something labelled Pool Salt will make the sky fall, your SWG explode and your pool turn colors.
    Luckily Morton Pool salt at Walmart is only 5.79/bag around here, so its not much more expensive than the alternatives. Only about $1.00/bag extra.
    Dec 2009
    Central Massachusetts
    2,690
    I like the pool salt for the reason that is HAS been put thru a grinder, and there is no chance of any pebbles in it. In aome cases these pool cost upwards of $60,000 to install. Why get cheap over a couple of bucks.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    38,539
    I fail to see how a pebble sitting on the bottom endangers the pool, but to each their own.
    Many people come here to learn how to maintain the pool and save money while doing do. We just offer the information about the alternatives that are identical and cost less money.
    Apr 2013
    Columbia, SC
    27
    Quote Originally Posted by bk406
    Interestingly, I added Morton Pool Salt to my pool a few days ago, and the next day when I went to clean out the vaccum bag/net of my Polaris robot (Swiper), it had picked up pebbles (or at least they were hard, small objects. Not sure what the material was...perhaps rock)
    15,694 gallons, Sta-Rite DE filter, 3/4 HP Heyward Superpump, Polaris
